Installing fuel Injectors
as the topic said, I just got the new 1s i need (thanks pat), ive got the rail off, the injectors seperated and the 3 busted injectors out.
what is the best way to put the new injectors in and put everything back together?
-Jeff
Use new o-rings if you don't already have them, on all the injectors, coat the o-rings with trans-gel (Vasaline) makes assembly much easier.
my biggest problem right now is getting the fuel regulator (i think thats what it is), that sits between the rails wont pop back into place, ill take another shot saterday.
-Jeff
