Is the carpet convertible specific? or will the 2dr carpet fit? The auction below specifically mentions "not for convertible" so I am confused as to if they are full of shit or not. Also on a side note, does anyone have any experience with aftermarket carpet bought from eBay or similar?
http://cgi.ebay.com/ebaymotors/1993-1996-OLDSMOBILE-CUTLASS-SUPREME-2-4-DOOR-CARPET_W0QQcmdZViewItemQQhashZitem35a532466aQQitemZ230404802154QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Thanks!
I read just the other day a mention of this by that member that used to work on the Cutlass convertibles when they were being built... The posting is in the Convertible section, the topic says something about "being able to help".
I remember he said the carpet WAS convertible specific, and said something about the wheelhouses being smaller...
That being said, if that was correct, it seems as if a regular carpet could be used...but with all the bracing and other mods made to the cars to make them convertibles, that could make a difference.
I found the thread...
http://www.w-body.com/forum/index.php?topic=79615.msg1077984#msg1077984
i got a coupe carpet that i am going to be putting in as soon as my fat max arrives, I heard that it wont fit also but that being said i cant imagine not being able to make it work. i have the carpet cleaned and ready to go in but i dont wanna paint it until i know its gonna work.
Aftermarket carpet sucks ass. If I were you, I would try to find a good replacement from the junkyard. Really sucks, but the aftermarket stuff never fits right, needs cutting, etc...
thanks for the tip! I knew that some one around here had to have tried aftermarket stuff...
A DIY job would look much better than after market. If you took the time to do it properly your looking at 100 to 150 $$
I plan to add some acoustic liner, underlay and carpet. Seam tape works well, try to get the widest material possible so the seams can go under the front seats.
Good luck, and send some project pics.
yeah that carpet was pretty much the worst fitting stuff ever.
I just replaced the original carpet in my convertible with really nice carpet from a four-door.
I laid the four-door carpet out on the ground and then laid mine over it since I had to cut out the console/shifter hole. I used my Leatherman. After washing it at my local car wash and air-drying with a box fan for a week, it went in and settled well. No issues. The carpet may be a bit longer under the rear seat but it does go in without trimming.
awesome!!! I was hoping that someone had put in coupe/sedan carpet without major issues :jeremy:
