paulo57509 Posted December 5, 2009 Report Posted December 5, 2009 I need to replace the ignition switch on my '92 Euro. If I go by the book, I'll have to remove the column from the car. I'd rather not do this if possible. Has anyone done this R&R without removing the column? TIA Quote
5speedz34 Posted December 8, 2009 Report Posted December 8, 2009 http://www.tgpforums.com/index.php/topic,3379.0.html Quote
White93z34 Posted December 8, 2009 Report Posted December 8, 2009 I think he is refrenceing the actual switch, which is mounted on the top of the column near the bottom. in which case you need to lower the column. just 4 13mm fasteners and it is down. Quote
paulo57509 Posted December 9, 2009 Author Report Posted December 9, 2009 Thanks, guys. Yes, I was referring to the switch down at the bottom of the column. Quote
