Galaxie500XL Posted December 3, 2009 Report Posted December 3, 2009 My '95 Cutlass Supreme convertible has the factory Delco stereo with cassette, 6-speaker option, and SWRC. My car also has the automatic climate control system. I was in the junkyard today, and saw a '95 Aurora with the cassette/CD stereo. The SWRC controls look just like the ones in my Cutlass. Is this a plug-and-play swap? Additionally, I read on this board that the Theftlock is engaged on all the Auroras....is this correct, and if so, how do I overcome this? Thanks; Daniel in Knoxville Quote
88red4cyl Posted December 3, 2009 Report Posted December 3, 2009 Additionally, I read on this board that the Theftlock is engaged on all the Auroras....is this correct, and if so, how do I overcome this? http://www.w-body.com/forum/index.php?topic=31841.0 Quote
Crazy K Posted December 4, 2009 Report Posted December 4, 2009 Taylor has done this.... he used an aurora wheel in a 95 CS, iirc. Quote
jeremy Posted December 6, 2009 Report Posted December 6, 2009 Taylor has done this.... he used an aurora wheel in a 95 CS, iirc. what are the differences between the two? they look identical Quote
tdvs Posted December 7, 2009 Report Posted December 7, 2009 Did the Aurora have both cassette and CD loading in the face? Quote
ManicMechanic Posted December 7, 2009 Report Posted December 7, 2009 Taylor has done this.... he used an aurora wheel in a 95 CS, iirc. what are the differences between the two? they look identical Emblem is slightly different as the Aurora is similar to the newer Olds Rocket only with an "A"... Did the Aurora have both cassette and CD loading in the face? Cutlass and Aurora do interchange. Quote
tdvs Posted December 7, 2009 Report Posted December 7, 2009 What do the emblems have to do with the radios being the same or not? Quote
ManicMechanic Posted December 7, 2009 Report Posted December 7, 2009 I had already answered that question. I was answering another. Quote
tdvs Posted December 7, 2009 Report Posted December 7, 2009 I was answering another. I should just let this go, but you have me baffled. What question had to do with the emblem? Did I miss something? Quote
ManicMechanic Posted December 7, 2009 Report Posted December 7, 2009 Going back, I was a little baffled myself. I read it as Jeremy asking about the differences between the Cutlass and Aurora wheel. :dunce: :dunce: IT'S KEN'S FAULT! Quote
Crazy K Posted December 7, 2009 Report Posted December 7, 2009 Going back, I was a little baffled myself. I read it as Jeremy asking about the differences between the Cutlass and Aurora wheel. :dunce: :dunce: IT'S KEN'S FAULT! LMAO!!!!! the radios are the same radios. the airbags are the same except the emblem has been updated.... even the SWRC are the same IIRC... Quote
tdvs Posted December 7, 2009 Report Posted December 7, 2009 even the SWRC are the same IIRC... Correct. I just got a set from a '95 Aurora a couple of weeks ago that are the same as those on my '95 vert. Quote
Galaxie500XL Posted December 8, 2009 Author Report Posted December 8, 2009 Been rather busy the past few days...they do interchange quite nicely. Found it in a local junkyard for $20.46, including the tax! Unfortunately, it appears to be unreliable. It works flawlessly at times, then begins spitting out the CD and giving "E20", "E21", or "E23" errors. Tried both the old-fashioned CD lens cleaner disc, and manual cleaning with alcohol, no change. It appears that the CD mechanism is pretty much toast. A shame, because cosmetically, the only thing wrong with it is the backlight for the far left side needs replacing. This is the first one of these I found in even close to decent condition...anyone got one that would be suitable as a donor for parts? Thanks, everyone, for your help! Daniel in Knoxville Taylor has done this.... he used an aurora wheel in a 95 CS, iirc. what are the differences between the two? they look identical Emblem is slightly different as the Aurora is similar to the newer Olds Rocket only with an "A"... Did the Aurora have both cassette and CD loading in the face? Cutlass and Aurora do interchange. Quote
Crazy K Posted December 10, 2009 Report Posted December 10, 2009 does the reverse side have an aluminum T as a heat sink? there are two versions of that radio. FYI I have 6 or them, and only one works. Quote
Galaxie500XL Posted December 14, 2009 Author Report Posted December 14, 2009 The cassette stereo I took out has the "T", but I'm thinking this one was shaped differently back there. I'll admit, I didn't look too closely at the time... I was afraid I'd find out they are unreliable...thanks for the info. does the reverse side have an aluminum T as a heat sink? there are two versions of that radio. FYI I have 6 or them, and only one works. Quote
Crazy K Posted December 15, 2009 Report Posted December 15, 2009 there are ones with and without a "T" the ones without are newer = more reliable. Quote
Galaxie500XL Posted December 16, 2009 Author Report Posted December 16, 2009 That's very useful information...thanks! What cars/years are compatible with my '95 and swrc? I've got several junkyards out here...just need to know which cars to check. Thanks! Daniel in Knoxville there are ones with and without a "T" the ones without are newer = more reliable. Quote
Crazy K Posted December 16, 2009 Report Posted December 16, 2009 this radio was used in bravadas, and all other models from 95-01ish.... if it has the same face, it should work... Quote
Galaxie500XL Posted March 26, 2010 Author Report Posted March 26, 2010 Update: After finding two junkyard units that had bad CD players, I finally just replaced the stereo with a NOS Oldsmobile CD/Cassette player that looked just like the bad ones I'd been seeing in the Auroras. Since the car is a convertible, and I wanted to retain the SWRC controls, the factory unit was the best bet. I'd rather not have some idiot slicing the top on the car just to steal the radio... $179.00 was a little more than I wanted to pay for a factory radio, but I figured since it's NOS, maybe it would last a while. Besides, it's not scratched anywhere, and all the faceplate lights work...something I never found in the junkyard stereos.. Thanks to everyone who helped! Quote
