ZeeQuick Posted December 1, 2009 Report Posted December 1, 2009 A couple of days ago started getting a very loud whining noise from under the hood, almost sounds like the supercharger or a dentist drill. It does change with the RPMs, hear it in neutral or park if you rev the motor. Can hear it over the radio or heater. It will not do it all the time, sometimes I will start the car and drive and never hear it. Other times it kicks in after about five minutes and remains until I park and shut it off. Car runs fine, no hesitation or stumbling. Sounds like its coming from the alternator/supercharger/power steering pump section. If I have it in park and just turn the wheel, the sound amplifies....so I was thinking power steering pump. Haven't checked the fluid, as that sucker is buried. More than likely power steering pump starting to go you think? How much for one of those suckers? 3800 Series II Supercharged btw. Quote
RobertISaar Posted December 1, 2009 Report Posted December 1, 2009 Haven't checked the fluid, as that sucker is buried. Quote
Q-Ball Posted December 2, 2009 Report Posted December 2, 2009 check the fluid! Mine was whining for a few days. Somehow my cap got loose and was loosing the fluid. Just topped it up and made sure the cap was on tight. Quote
94 olds vert Posted December 2, 2009 Report Posted December 2, 2009 I bought my car and it had almost not power steering fluid in it and it whined really loud. Filled it up and never a problem since, But did found out it leaks. Quote
ZeeQuick Posted December 2, 2009 Author Report Posted December 2, 2009 So, ummmm.....guess I should check the fluid first Quote
ZeeQuick Posted December 2, 2009 Author Report Posted December 2, 2009 Where is the reservoir at anyways? Do you have to get to it from under the car? Quote
Night Fury Posted December 2, 2009 Report Posted December 2, 2009 No you don't have to get under the car. Just reach farther! Quote
BCM Posted December 2, 2009 Report Posted December 2, 2009 My Intrigue had power steering whine since day 1. It was kinda loud, but it always had plenty of fluid. I actually have a video of it. Quote
AL Posted December 2, 2009 Report Posted December 2, 2009 Its on the back side of the motor towards the bottom... You can see it if you look down while standing on the pass side... Quote
Leadfoot Posted December 2, 2009 Report Posted December 2, 2009 Put some Lucas in there Don't do this. Lucas will help for a very short period of time. Then it will turn your PS fluid into a separated mixture of good and fluid which will ruin your pump. I had this happen on my Jeep. Each time I replaced the pump I flushed everything as much as I could, but I would find the same thing after driving with the new pump on for a few months. Finally, the last time, I took everything off the Jeep and flushed it clean. Lucas is garbage. Several of my buddies working at the dealership laughed at me because they told me not to do it and had seen similar things. I was broke and in college at the time and thought this would be the cheap way out. It end up costing me more $$ and a ton of time in the long run. If it leaks, replace it. Fix it right and forget about it. Quote
MonteCarloChick Posted December 2, 2009 Report Posted December 2, 2009 Lucas is far from crap. Yes it's a temporary fix in MOST cases. Quote
digitaloutsider Posted December 2, 2009 Report Posted December 2, 2009 With these cars, I'd frankly be more worried about it being the transmission pump. Can you pinpoint which side iof the engine by it's coming from? Quote
White93z34 Posted December 2, 2009 Report Posted December 2, 2009 or whif the accessory belt off and run it for a minute and see if the noise is gone. don't run it any longer though, no waterpump = unhappy car. Quote
Euro Posted December 2, 2009 Report Posted December 2, 2009 With these cars, I'd frankly be more worried about it being the transmission pump. Can you pinpoint which side iof the engine by it's coming from? I fear that that's what my noise is. Mine whines like the typical 3800, but the fluid is full...AND the pump is brand new...and it still whines. Quote
White93z34 Posted December 2, 2009 Report Posted December 2, 2009 I've had even new pumps whine, the last one I had on the bonneville was a brand new reman, that whined like a wookie for 6 months, I took it back and put a used one on, been golden since. Quote
ZeeQuick Posted December 2, 2009 Author Report Posted December 2, 2009 Its not the transmission pump. Coming from the passenger side of the motor, I can tell you that much. Really seems to come and go, but you can definitely hear it get whinier when making a turn. Thanks for all the replies guys! Quote
ZeeQuick Posted December 3, 2009 Author Report Posted December 3, 2009 Yeah, so its amazing what a little power steering fluid will do. Pulled out the cap and the stick was dry. Added fluid and sound is gone. Gotta love it when its something simple. Damn used cars. Quote
Regal_GS_1989 Posted December 3, 2009 Report Posted December 3, 2009 With these cars, I'd frankly be more worried about it being the transmission pump. Can you pinpoint which side iof the engine by it's coming from? I fear that that's what my noise is. Mine whines like the typical 3800, but the fluid is full...AND the pump is brand new...and it still whines. I'd say pull the belt and see if it still whines. If it does not, then check the alternator. I have had the bearings on a couple of them go bad and each time the sound seemed to be something different. Hell, I replace the PS pump on my truck because I was sure that was making noise (The pitch even changed when you opened the reservoir, but it was the alt all along. Quote
Euro Posted December 3, 2009 Report Posted December 3, 2009 With these cars, I'd frankly be more worried about it being the transmission pump. Can you pinpoint which side iof the engine by it's coming from? I fear that that's what my noise is. Mine whines like the typical 3800, but the fluid is full...AND the pump is brand new...and it still whines. I'd say pull the belt and see if it still whines. If it does not, then check the alternator. I have had the bearings on a couple of them go bad and each time the sound seemed to be something different. Hell, I replace the PS pump on my truck because I was sure that was making noise (The pitch even changed when you opened the reservoir, but it was the alt all along. I thought about the alternator, but I'm pretty sure that's fairly recent. I'm going through my receipts to see for sure. Quote
KingVee Posted December 5, 2009 Report Posted December 5, 2009 With these cars, I'd frankly be more worried about it being the transmission pump. Can you pinpoint which side iof the engine by it's coming from? Mine whines like the typical 3800, but the fluid is full...AND the pump is brand new...and it still whines. I love this little whine 3800's make, I don't know why. It's unique to it, me thinks. Quote
AL Posted December 6, 2009 Report Posted December 6, 2009 Yah, My car has a slight whine to it also... Its always been there and its never gotten worse and nothing is bad so I just let it be Quote
Addicted to eaton Posted December 6, 2009 Report Posted December 6, 2009 i have a new ps pump (rockauto) (5k miles TOPS on it) ill send for 30 shipped. if you need it. Quote
