engine knock
okay so for the last month or so my engine has been knocking on startup it is finally annoying me and worrying me. i have checked the oil and it is fine. it will start knocking about 10 seconds after i start it and continue untill i get off of idle. and then it will be gone for good once the engine is warm. what could cause this and is it hurting anything im thinking it might just be sme piston slap. which wont hurt anything right?
thanks
jake
Knocking or ticking? I ask since there are major differences in sounds and all to often people confuse different engine sounds with the atypical "Rod knock". Also, there's some simple math involved to figure out if it's in the valve train vs. the lower end. Usually valvetrain noises will occur at a slower rate than the the lower end since the cam(s) revolves once for every 2 revolutions of the crankshaft.
i want to say it is a knock because it makes its normal lifter tick also
i forgot to clarify that was in my dads mustang LOL
Well, you can certaintly narrow it down somewhat with a mechanics stethoscope (if you have one or can find one; they're relatively inexpensive) Just probe around and you'll probably be able to pinpoint it. If you're for sure it's a distinct lower end knock, and can verify it, then you're probably fuxored. But, you can gimp it along by dumping some heavier weight oil (like 10w30 instead of 5w30) in and or adding any kind of additive of your choice. Might keep you going awhile longer.
EDIT to both posts: (I just reread OP more closely) sounds like it's your typical piston slap, but why you've only noticed it in the last month is peculiar
When the 4.3 in my blazer went it sounded like a tick in the bottom end. I drove it 700 miles that way before it spun the
a main.
could it be due to weather since i live in az it is finally just getting cool out. because in the summer it has been known for us to park the car at 11pm and the engine still be warm at 8am so it is finally getting cooler starts
oh and note. it didnt do it this morning
More info on the Mustang...Year, engine, miles, anything else important?
the knock is in the cutlass the burnouts were in the mustang
but if you were just interested in the mustang
it is a 98 gt with 62k miles
No weather in AZ is cold enough to do any harm!!
LOL youd think. you should here my car on a 40* morning. the suspension creaks, the powersteering groans, and the engine whines a bit. its like the car has adapted to the climate LOL
Sounds like your car is a wuss :lol: Bring it up here and have it experience a -40 start in the morning, and it'd probably blow out every single gasket there is :lol:
the -15 mornings we have here occasionally are bad enough.... i can't imagine the noises an engine would make at that temperature...
Surprisingly...it is not all that bad (depending on your car obviously). Other then a few extra seconds of valve noise, all I get is an extra whiney power steering pump for the first few minutes. You need to let it run for about 10 minutes before you go anywhere though, otherwise you can cause all sorts of issues.
My Lumina does the same thing, slight light knock at cold startup but goes away once warmed. This car had the typical intake gasket leak when I bought it so I figure the noise is just a slightly worn piston(s) due to the coolant getting into the cylinders and washing out the oil enough to wear it out. When the engine warms up, the aluminum pistons expand enough to fit the cylinders better. I've been driving the car for three years, and I'm not easy on it either! Just let the engine warm up for a few minutes and be good about changing the oil. Oil weight didn't matter with my car so stick with whatever your using.
My wife just bought a 2003 Olds van with the 3.4 and that one has a bad lifter rattle at start up! Strong engines but noisy.
I agree it just sounds like its piston slap.
However, try to get a good video if you can! It never hurts!
Gotta love the month long -40 starts haha...Lumina always starts but sometimes pukes the power steering fluid hahaha...TSX doesn't really care. The engine mounts are so cold though that the dash rattles!
This is what the TSX sounds like turning over lol...all my LCD displays are like his too - half show up,etc. When you turn the radio up and down the display just scrambles!
why was this moved to other cars?
oh and i had my neighbor look at it since its intermitent and its location make him think it a bad (idle tensioner pulley or something like that)
Apparently now they think cutlass convertibles are no longer w-bodies? Nothing surprises me here anymore :lol:
I think he meant to say he did burnouts in the Mustang, not the Cutlass. I think the knock is in the CS.
