Fog Lights Don't Work - 99 Regal
Both fog lamps on my recently acquired Regal do not work. So far I've determined that its not the bulbs, its not the switch, its not the relay or the fuse. Anything else I'm missing before I start tracing wires?
Hey, likely scenario.....but no, low beams or parking lights.....fogs don't work.
Did you check the sockets? Check first of all that they are clean, and check for voltage with a Multimeter.
When my fog lamps didn't work it was because of the flasher.
If there is no power going to them might be a short somewhere.
Guess the only other option is to crack open that loom and see what there is to see. I want fog lights!
make sure the car is not in "parade mode" the interior lights cannot be illuminated at the max level wile using fog lamps check the rheostat or potentiometer for the dimmer switch and make sure its not that max position!
what does a blinker flasher have to do with fog lights?
Mine would only work with the brights on, When I put in a new flasher they worked correctly with the brights off.
  • 2 weeks later...
So I consulted the owners manual, nothing in there about parade mode. Foglights don't seem to be affected with the setting on the dimmer switch...either way they don't work.
