AWeb80 Posted September 16, 2003 Report Posted September 16, 2003 Anyone know, I was wondering cause i've been doing alot of thinking in my head for when I get around to the L67 swap. I'm gonna want to have that 4T65-HD cause I'd like to get around 380-400 HP out of the L67. I would like to do a total rebuild. 8) Quote
The Burning Rom Posted September 16, 2003 Report Posted September 16, 2003 99-03 (maybe 98s?) Grand Prix GTP/Buick Regal GS. I'm not sure what tranny the Montes used....or if any of them would have used the HD version. :? Quote
Pselus Posted September 16, 2003 Report Posted September 16, 2003 not to steal the topic...but what tranny was in my car? and is it a bad one? (3.4 engine) Quote
The Burning Rom Posted September 16, 2003 Report Posted September 16, 2003 not to steal the topic...but what tranny was in my car? and is it a bad one? (3.4 engine) 4T60E HD if it was a 3.4 DOHC motor. They're not the strongest of the transmissions. The non-E version seems to be more reliable for some reason :? At least in my opinion. Quote
99RegalGS Posted September 19, 2003 Report Posted September 19, 2003 I think the 4T65E was in the 97+ GTP and Regal GS. I the newer Pontiac, Chevy and Olds minivans with the tow package have it and the bonniville SSEi and park ave ultra. Quote
99RegalGS Posted September 19, 2003 Report Posted September 19, 2003 sorry, Iment to say 4T65E HD Quote
Pselus Posted September 19, 2003 Report Posted September 19, 2003 how's a 282 five speed from an 89 cutlass rank? Quote
Mike J. Posted September 19, 2003 Report Posted September 19, 2003 The 97-98 Regals and GPs did have this trans, maybe even the 96 Regal too. For the last couple years almost all GM v6's get the 4t65-e. Only the cheapest cars don't such as the Malibu. Granted some GM v6's get a 5-speed auto also. You can go to GMPOWERTRAINS.COM and go to the trans. section I believe for the current cars with their trans's's's. If thats not where I saw it, do a search on Google for "4t65". Quote
timg Posted September 19, 2003 Report Posted September 19, 2003 For some reason, some of the 97 GP's had 4T60e's. ZZP was running their stock tranny well into the 12's (with CSC AND high RPM!). I'm not sure what's happened to it now. Tim Quote
Heza Posted September 19, 2003 Report Posted September 19, 2003 not to steal the topic...but what tranny was in my car? and is it a bad one? (3.4 engine) 4T60E HD if it was a 3.4 DOHC motor. They're not the strongest of the transmissions. The non-E version seems to be more reliable for some reason :? At least in my opinion. i thought the 3.4 got the 4T60E. the 4T60E-HD was on the Cadi 4.9 Quote
Bolt_Crank Posted September 19, 2003 Report Posted September 19, 2003 my Z has the 4T60E it doesn't say HD anywhere on it... Quote
CPSMonteZ34 Posted September 21, 2003 Report Posted September 21, 2003 Auto Monte's with the 3.4 DOHC run with the 4T60-E They used the 4T65-E in the last one (maybe one-and-a-half) years of the Monte's life when the transition was made to the Series II 3800. The Monte never came with the HD version...that was primarily used in all of the cars with the Series II 3800 Supercharged engine. The 4T60-E is reliable with an every day use car. It cannot handle too much repeated extra stress for any length of time. Overall, it's a transmission that operates normally if not beaten on every day. Quote
brian89gp Posted September 21, 2003 Report Posted September 21, 2003 the 3.4 DOHC got the 4t60e-hd. And if you're doing a L67 swap as long as it comes with a 4t65 (some of the early ones used the 4t60e) it will be a 4t65-hd Quote
CPSMonteZ34 Posted September 21, 2003 Report Posted September 21, 2003 Exactly what is the GM designation for this so-called 4T60-E HD? I'm only asking because that's only transmission I've found mated to both, the 3.1 and 3.4 - the only other before it was the 4T60 - being the vacuum shift controlled transmission while the E simply stands for electronic shift control (still vacuum assisted though). Quote
99RegalGS Posted September 22, 2003 Report Posted September 22, 2003 The 4T80-E is stronger than the 4T65-E HD and it should bolt up to the L67. Quote
99RegalGS Posted September 22, 2003 Report Posted September 22, 2003 here's a link to it. http://www.gm.com/automotive/gmpowertrain/transmissions/hydra/apps/4t80.htm Quote
brian89gp Posted September 22, 2003 Report Posted September 22, 2003 Dunno the designation for the HD, but I know the 3.4 got it. The 4T80-E is stronger than the 4T65-E HD and it should bolt up to the L67. Sure will but it won't fit into a w-body. Well, to be fair, if you take the brake booster and master cylinder out it *might* fit. Quote
timg Posted September 22, 2003 Report Posted September 22, 2003 Some of the 97 Monte Carlo Z34's with the LQ1 also got the 4T65E. My 4T60E has lasted 133k miles to this point. The only problem with it is slipping clutch packs. I've put 70k miles on this car and they've been about half HARD city driving and half interstate and backroads driving. At 75k miles, I put on an intake and exhaust. Those two mods alone were worth about 25-30 hp at redline vs a stock 3.4 (based on my dyno vs other LQ1 dynos). They didn't add much below 5000 rpm though. My turbo has been on for over 10k miles now and the only casualty so far has been the clutch packs which have been wearing out ever since the exhaust went on. I think the 4T60e itself is much stronger than most give it credit for. Tim Quote
CPSMonteZ34 Posted September 23, 2003 Report Posted September 23, 2003 That very well may be that the 4T60-E deserves more credit...but I listen VERY carefully to how my second transmission is operating. This is because my first gave up at around 64,000 kms (normal highway driving, no racing or deliberate abuse). I guess I just got a crappy tranny - but that's still rediculous. After checking things out, the 4T60-E is a stand alone. Anyone looking for an HD version (in case they think of it being available in case they are searching for a 'heavy duty' version) won't find it as any kind of a stock production transmission. Just thought I should point that out. Quote
