Mysteriphys Posted November 20, 2009 Report Posted November 20, 2009 Just wondering if anyone has any ideas for pulling the bottom end of the bolt that goes through the bar that goes from the radiator support to the strut tower out, I managed to bust the top off, and broke a friggin easy out off inside it... so aside from burning it out with oxy torches, any ideas? Quote
White93z34 Posted November 20, 2009 Report Posted November 20, 2009 In the past I have drilled. Its not a perfect answer. but a 3/8s tap and corresponding hardware will work. Quote
mfewtrail Posted November 20, 2009 Report Posted November 20, 2009 I managed to bust the top off, and broke a friggin easy out off inside it... Is the easy out sticking up above the surface any? If so, try to find someone w/ a welder to weld a nut to it. Other than that, it's going to be a pure pain the ass to remove as those things are insanely hard. Here are some easy out removal discussions if you're interested. http://www.snowest.com/forum/showthread.php?t=54904 http://www.advrider.com/forums/showthread.php?s=9ddb0ebd6d2ab85d006adc17d3008d69&t=153648&page=2 http://www.opelgt.com/forums/mechanical/10233-broken-easy-out-sequel-i-keep-breaking-bolts.html Quote
