Grim diagnosis; 2006 Monte Carlo LT, 150K; Fully stripped pics pg 7!!
At the very least...they are leaking externally and not causing serious engine damage like the LIMG's on the 3x00's.
Thats whats happening to mine! :sasun:
  • Replies 138
  • Created
  • Last Reply
Top Posters In This Topic
  • Night Fury
    58
  • 88red4cyl
    18
  • RobertISaar
    9
  • BXX
    8
cracked? are they iron heads or what? aluminum shouldn't crack under almost any circumstance...
nope, aluminum. And this has happened LOTS! We've done 20+ cars last year.
Ours had 60K and the headgasket is leaking..
I saw one at work today with 39K and it was leaking
:facepalm: Lets go back to SBCs please...
No thanks!
you wouldn't think it would be a tall order for GM to design something that doesn't leak or need gaskets on a regular basis. The escort we own, 170k, never needed one gasket. Whats so hard?
^ TRUTH!
on the 95, the only thing even close to internal, or a gasket, that's needed replaced was a water pump, and that was back in like 1997/8. since then, no engine issues at all...
  • 2 weeks later...
Buck, assuming you've gotten the parts for this, how much did the gasket set and bolts run you?
Gasket set, includes ALL gaskets(Headgaskets, valve cover, LIMG, UIMG) $180, I believe.
I have not got bolts yet...
  • 2 weeks later...
Have you gotten bolts yet Buck? The dealer told me something crazy like $200 for headbolts... I'm praying they're wrong...
on rockauto, they are 15.33.... i really hope that isn't each
They dealer told me 16 of them were $8, 12 of them were $4, and the other 4 were like $6... I can't see how it can have 32 headbolts though... The parts guy said I'd need all 32... I've never heard of a car needing that many headbolts though..
That's the only thing stopping me at this point is the head bolts. I'll go back Monday and inquire
  • 3 weeks later...
I received all the information I need and will begin once I buy the bolts and the weather warms up a bit.
there should be 16 headbolts iirc
Yes sir, You are right and I had just recently figured that out. Everyone seemed to want to sell me 32. I was like REALLY?! PASS!
Does anyone know if I could get the revised bolts anywhere but the dealer?
I doubt it Buck... How much did the deaker quote you for the ones you'd need?
I can't remember but it was either $215 or $250 BUT that was for 32. So 110 or 125
The process begins:
This is about an hour's worth of work:
width=1280 height=959http://i182.photobucket.com/albums/x218/NHGC_Vineman/SANY0285.jpg[/img]
width=1280 height=959http://i182.photobucket.com/albums/x218/NHGC_Vineman/SANY0286.jpg[/img]
width=1280 height=960http://i182.photobucket.com/albums/x218/NHGC_Vineman/SANY0287.jpg[/img]
I took this one before I took the fuel rail off, so pretend that is off too :lol:
width=1280 height=960http://i182.photobucket.com/albums/x218/NHGC_Vineman/SANY0288.jpg[/img]
what IS the difference in the bolts?
For the heads? I guess the revised set has bigger bolts for the corners, so I guess we'll see!
How much did you end up paying Buck for the revised set?
Haven't got them yet :lol:
I was going to wait to start until I got them, but my mom isn't driving the car anyways so I figured I might as well start.
Alternator, coil packs, dogbone mounts, power steering pump, wire harness all off and out of the way.
Time for big business now!
