Tensioner? Belt noise....
I had a question about some belt noise on my 95... Last Saturday it started making an embarrassing amount of noise, and it seems to be coming from the belt area. I pulled the belt off and spun the pulleys by hand... The water pump, ac condenser, and the tensioner all made some noise when spun... So, unable to figure out which was the culprit, I put the belt on and continued to drive it... Flash forward to today, and it is driving me crazy with all the noise. So I popped the hood and decided to listen and see if I can hear where its coming from better...
So I put my ear right next to the water pump, and I didn't hear anything that sounded like my noise... When I moved my head above the power steering pump, the noise was very loud... I think it is echoing up off the strut tower through... So that would have to be the power steering pump, tensioner, or the huge pulley at the bottom of the belt, unless the noise is echoing from the front back...
A few other notes about the symptoms: The sound seems to get drown out at higher rpms... When I rev it a little bit, the noise does not seem to get louder with the engine load... The car has also been idling rough since this started happening... Not super rough, but not smooth like it had been before... Not sure if either of those things are helpful, but I thought it was worth noting...
Get a mechanics stethoscope and CAREFULLY listen near the pulleys while the engine is running and you should easily be able to discern which pulley is producing the noise. Harbor freight has them for ~$5 and part stores are usually no more than $10 for them(autozone has a lifetime warranty on their 'scope and the other stores might as well).
Does it sound like a metallic grinding noise? Could be your A/C clutch going bad.
Does it sound like a ringing bell? If so, it's the A/C clutch... Turn on the A/C so the compressor kicks on and it should go away.
Replaced it on the 96, part was $40 from the dealer and I can't remember how it was to do, on the 97 it does it intermittently so I just let it go.
I've had that noise for a long time.. This noise is still present when the ac compressor kicks in...
I should have asked, does the A/C work? If it doesn't, the compressor wont kick on and the noise will stay on.
The ac does work. The compressor takes a while to kick in on really cold days, but it does eventually come on..
Ok, then it must not be the A/C clutch. Take a screw driver and put it on different things and listen through the handle... you should be able to hear what is going bad that way.
Dumb question, but how do you put the screwdriver on things that are spinning?
Yeah don't put it on moving things that won't be good. Put it on the top of the alternator, or on the snout of the water pump...or on the body of the A/C compressor. You should be able to hear whichever is making noise through the screw driver.
All right... Whatever day it quits raining I will try that and report back with what I find!
I wouldn't be surprised if it is the alternator....My Cutlass made noise, the one in my truck made noise, and the one in my 2000 also seems to make a tiny bit of noise when cold. If you wanted to, you could spray a little bit of spray lube/penetrating oil onto the bearing and see if it makes a difference. The whine can sound like power steering whine as well, and in the case of my truck, I actually replaced the pump because that is where it seemed to be coming from. The noise actually even changed when I would open up the power steering reservoir. Alas, it was the alternator all along. New alt and now it is silent.
So what exactly am I listening for, as far as sound goes? I did the alt, power steering pump, ac compressor, and water pump, and it sounded almost exactly the same for all of them.. To me, it just sounded like a low hum on the water pump and power steering pump, while the ac and alternator had a higher pitched hum... I couldn't safely reach the tensioner or the crank pulley with the longest screw driver I had, so I don't know how they sound...
Generally a hum that is different from the rest or more of a vibration in different components...or both.
I've got an alternator I've been needing to throw on it for some time anyway... Planning to do that Saturday, and then see where I'm at...
Put the new alternator this afternoon... While the car definitely needed a new one (now the lights don't dim to the point of barely being on when you turn on the fan), it didn't help the noise from the belt area... Since I can't tell anything from the screwdriver, I guess I am going to have to invest in one of those stethoscopes tomorrow...
I bet it's the actual tensioner since you can't seem to pinpoint the noise.
When I listen with my ears, it sounds the loudest right above the tensioner, but noise can carry and echo off the fender... I was kind of leaning towards that to begin with, but the tensioner doesn't have any side to side play that I can detect, and I can't get my screwdriver to reach a spot on it that isn't moving to listen to it... Could it still be the tensioner even without play?
yeah, the bearings could be going bad.
Would that require replacement of the whole tensioner, or just the pulley?
Anybody know?
