vdaily89 Posted September 16, 2003 Report Posted September 16, 2003 Took the car to Big-O to have a screw taken out of front -driver side tire and fixed. When I left and was driving down the road I noticed the anti-lock(ABS) light was on the dash. I have no turn signals or brake lights. I pulled the fuse and relay from the box under the hood and both seem to be okay. Fuse isn't broken and I am honestly not sure how to tell if the relay is o.k. Could the guy at Big-O have hit something to cause this or do I have another problem?? Thanks, Vince Quote
cutsup1996 Posted September 16, 2003 Report Posted September 16, 2003 this may or may not have anythng to do with your car but that happened to me before too a lot with my cutlass, i couldn't figure it out for my life. i would have never thought it was from my lower intake manifold leaky gasket. it was causing a change in vacuum lines and stuff, and coming to a stop the rpm would take a quick dip and then the abs light came on but nothing else was wrong. after me and my bro fixed the gasket no more abs light coming on, funny that was the only light coming on from a busted intake manifold gasket Quote
vdaily89 Posted September 16, 2003 Author Report Posted September 16, 2003 The rpm's are fine and it runs/idles fine. This is the first time this has happened and it came out of the blue. Just kind of odd that it came on after they took the wheel off to fix the flat. Quote
cutsup1996 Posted September 16, 2003 Report Posted September 16, 2003 well dude sorry dunno what your prob is Quote
cutsup1996 Posted September 16, 2003 Report Posted September 16, 2003 only thing i know is make sure the abs connection is tight and everything else is tight and in place Quote
runt Posted September 16, 2003 Report Posted September 16, 2003 Check your fuses in your glove box. Had the same problem. Also, get new bulbs for the rear of the car and clean the connections that are on the car itself. After I did that, and replaced a 2 fueses, works great! Quote
vdaily89 Posted September 16, 2003 Author Report Posted September 16, 2003 Thanks guys. Isn't there a wheel sensor down by the front brakes? Could the guy have knocked it loose and caused this? I am just thinking it is no coincidence that this happened when I pulled it out after they messed with it. I will check the fuses again. Thanks, Vince Quote
Slade901 Posted September 16, 2003 Report Posted September 16, 2003 ABS has a wheel speed sensors on each wheels. He could have knock it loose or broke it. So better check those wheel speed sensors near the wheel/tire that the mechanic has repaired. Quote
vdaily89 Posted September 16, 2003 Author Report Posted September 16, 2003 where exactly is the sensor located on the brake/wheel assembly? Quote
vdaily89 Posted September 17, 2003 Author Report Posted September 17, 2003 Got it working, but not for sure how. I cleaned the wheel sensors but that didn't seem to help. Then I started pulling fuses and checking them. None were blown but I messed with the wires going to the fuse box on the drivers side under the hood. Then it seemed to work. Not for sure what I did but it's working now. Quote
