question on stock dogbone
does anyone know what the little ring on the stock dogbones are for on the 3.1? there is like a little loop on the bottom of the dogbones and im just wondering what that is used for and if its important, thanks
when you change the pluds and do some other work on the backside of the motor you will need to loosen the dogbones and remove the bolts.
the one on the driver side is used to put on of the bolts back through to keep the motor rocked forward.
Monty
