94slutlasssupreme Posted November 8, 2009 Report Posted November 8, 2009 ok so i rebuilt my 3800 last September 08 i've got 20k on the rebuild. And have replaced the harmonic balanced seal twice now and the damn thing is still leaking and i cant figure out why....both seals were felpro so im just wondering if maybe i should get one from gm or if anyone else knows anything I'm open to suggestions..... Quote
Andrew Posted November 8, 2009 Report Posted November 8, 2009 is the balancer damaged at all? you might try using a little rtv with the new seal. Quote
BXX Posted November 8, 2009 Report Posted November 8, 2009 You need a repair sleeve for the harmonic balance, go to autozone. Should solve it, but more than likely you should get a new balancer for it. Its leaking because the seal wore it just enough to leak. The repair sleeve kit typically works, but not always Quote
94slutlasssupreme Posted November 19, 2009 Author Report Posted November 19, 2009 ok thanks for the info guys really appreciate it gonna try it soon ill keep updating this Quote
