Clutch is going in! Its in need help!
well i have been working on it for an hour.
I have the battery out, Sway bar off, hood off, both wheels (after i FINALLY found the locking lug nut tool lol!) air box, and driver side strut!.
WOOT wish meh luck!
An hour for just that??
Jeebus, quit drinken beers and BS'n with Buck and get to work Anthony :lol: :lol:
WTF I'm not even there! LOL
And you're lucky that lug key is even with that car!! Surprised me when I saw it for sure!
lol. my friend was like "Lockin lugs".. i go FUUUUUUUUUUUUUUUUUU lol
we got the Bitch bolt out. after driving 30 miles. taking 4 hours of beating and 20 min of heating and beating it it came out.. i fell horrible. its 30 i had a cold when i started. now i have a fever and am weak. getting some sleep then work like hell on the bish. I didn't see baillie today. and since i broke my phone i did not text her much at all either. i feel bad. But i think time apart is awesome! we spend every moment we can with each other and its getting old!
Ok clutch is in. the one i took out had no nothing left on it. But i got a few problems!
the clutch is very very easy to push.... to easy i think.
1st is almost impossible to get into sometimes.
when i go in reverse it grinds like the clutch is not fully letting off the fly wheel.
don't know how :) but i did what Chris said so i wouldn't have to.
Bleeding a clutch is a 2 person job given you dont have any fancy bleeding tools. Basically one pushes on the clutch pedal and another cracks the bleeder open then shuts it before the person pushing the pedal lifts up on the pedal. The bleeder should have the little nipple on the end going into a tube. This way air doesnt go back into the bleeder.
Now before you do this, it would be worth finding out whether the 282 has a way to adjust how the slave cylinder is pushing on the clutch fork. It could take a simple adjustment instead of bleeding it
It is non adjustable IIRC.
And honestly I can say I have no idea how to bleed a 282 clutch.
I'll check a FSM tomorow when I get home if no one else gets it before then.
sounds like it's done the exact same mehod as brakes....
and according to alldata, it isn't adjustable on the 89. there is a procedure for the 88 though...
You could also have a bad slave or master. You shouldn't need to bleed it if the system wasn't open. Good news is that either are cheap and readily available for the 282, unlike the impossible to find and bank account draining master and slave for the 284.
