SES Codes
CutSupreme93
I just checked for codes using the paper clip method and got 13,22,33,43. all of which seem to be voltage issues does this mean that my alternator isn't working properly or is my thinking totally off?
Does your alternator make a loud whine or buzzing like noise when you drive? If so that's a dead give away that the alt is about to crap out on you.
Im not sure i'll have to check later, i forgot to mention that i have a 93 LQ1 if that helps any.
13 is O2 Sensor, 22 is TPS, 33 is MAP, 43 is Knock Sensor...
want the specifics as to what causes the codes to be set?
these are the two you should be concerned with.
make sure to reset the ECM to clear the codes.
reset ecm and didnt even make it through 3 minutes of sitting in drive before it stalled. so i started it and with my foot on the pedal idled at around 1000 let it get to running temp and turned it off went back to check codes again and the only code showing is 43 knock sensor
