brianstarr58 Posted November 3, 2009 Report Posted November 3, 2009 Is there anything that I need to know about before attempting to put front and rear pads on my 95 Vert? I have installed brakes before but not on the Cutlass. Someone told that there are some special tools that I might need but he didn't know what. Quote
cutty Posted November 3, 2009 Report Posted November 3, 2009 yes you will need a t-60 socket for the fronts, and a brake cube or caliper compressor tool for the rear brakes. Quote
mra32 Posted November 3, 2009 Report Posted November 3, 2009 and a brake cube or caliper compressor tool for the rear brakes. Or a nice pair of pliers to fit in the divets and screw the piston back in, as in the Haynes manual Quote
Crazy K Posted November 3, 2009 Report Posted November 3, 2009 t60 is needed to remove the rotors, but if you are only doing pads you don't need it The rear pistons turn in. I've done it with pliers or wrenches... but you can also get a loaner tool from AZ designed to do the task. Once the rear's piston is in, there are two notches on the piston. These notches must be horizontally aligned. Quote
brianstarr58 Posted November 17, 2009 Author Report Posted November 17, 2009 got my brakes put on by my friend for 50 bucks...front and rear. still have the same problems though, soft pedal. how can you tell if the power booster is bad? Quote
