94 olds vert Posted November 2, 2009 Report Posted November 2, 2009 Its a 1994 built in late '93. With steering wheel controls and a cassette player. I found one at the junkyard, and it seems It should work. Plus I wouldn't have to cut my dash up its already red with a hud. Quote
Crazy K Posted November 2, 2009 Report Posted November 2, 2009 If it has automatic climate control it should. The only CS that I have ever heard of not being pre-wired was manics late production 94 vert. Of course adding the wiring is not hard... Quote
94 olds vert Posted November 2, 2009 Author Report Posted November 2, 2009 Yes, I have automatic climate control. Maybe I will see how much It will cost to buy the HUD from the junkyard. Quote
ManicMechanic Posted November 2, 2009 Report Posted November 2, 2009 Yep, my 1994 was NOT pre-wired for HUD although it had ECC and SWC. I did add it though, super easy. Quote
5speedz34 Posted November 8, 2009 Report Posted November 8, 2009 I've got a charcoal hud sitting at my parents house if your interested....came out of a 92-93 International. Quote
bg35765 Posted December 14, 2009 Report Posted December 14, 2009 Does the pre-wiring also include the adjustment cable? Or just the electrical wiring? I found one at the junkyard this weekend and pulled the cable just in case. Quote
Crazy K Posted December 14, 2009 Report Posted December 14, 2009 Does the pre-wiring also include the adjustment cable? Or just the electrical wiring? I found one at the junkyard this weekend and pulled the cable just in case. get the adjustment cable and switch! Quote
94 olds vert Posted February 27, 2010 Author Report Posted February 27, 2010 So I checked to see if my cutlass was pre-wired for hud. I found an unused female connector, and I think it might be for hud. I found it behind my gauge cluster. Quote
thatcutteeboy Posted February 27, 2010 Report Posted February 27, 2010 I've got a charcoal hud sitting at my parents house if your interested....came out of a 92-93 International. What's it hitting for? Quote
rockfangd Posted March 1, 2010 Report Posted March 1, 2010 that would be the hud unit plug, lucky. The other plug for the switch is usually tucked up behind the ECC unit, you have to pull it down to the bottom right of the sport pod. It is a black female plug with about 5 wires, pink, black, white, grey, and I think another black Quote
