tornado_735 Posted November 1, 2009 Report Posted November 1, 2009 I have been having an issue with cold starts. Every once in a great while, it will stumble and idle funny when I put it into gear when it is cold. I figure why not try the simple stuff first, and clean the IAC. I have no idea where it is located on the L82. Where is it? Thanks! Quote
19Cutlass94 Posted November 1, 2009 Report Posted November 1, 2009 top right of the throttle body Quote
tornado_735 Posted November 1, 2009 Author Report Posted November 1, 2009 top right of the throttle body Sweet. Thanks much! Found something weird when I went to look for a picture of the throttle body! Quote
hotrodolds Posted November 1, 2009 Report Posted November 1, 2009 Could be an IAC, could be a TPS, too. Are you getting any codes set? Quote
tornado_735 Posted November 1, 2009 Author Report Posted November 1, 2009 Could be an IAC, could be a TPS, too. Are you getting any codes set? Nope. I did have the SES light come on the other day, but I had forgotten to plug the random little sensor in that sticks in the side of the rubber intake hose. Plugged it back in and the light went off with a key cycle. Quote
