pDuB257 Posted October 28, 2009 Report Posted October 28, 2009 Okay so long story short I have a 98 Grand Prix GT naturally aspirated 3.8L motor. Coolant reservoir has some brown/black gunk in it and it needs to be changed. How do I flush the radiator and get all of this nasty stuff out of my coolant reservoir and cooling system? I bought some Prestone coolant radiator flush stuff and I also bought a gallon of DexCool which I will mix with another gallon of water as well once I flush all of this stuff out. My question is where is the drain plug for the radiator in order to make all this nasty stuff come out so I put the new stuff in? I have searched everywhere on the internet and have found no answers. Any help? Thanks. Quote
Andrew Posted October 29, 2009 Report Posted October 29, 2009 My question is where is the drain plug for the radiator on the bottom. the best flush method for Dex is the pressurized flush. Im lazy so i have a shop do it. how does your oil look? you may have a leaking intake or bad LIM gaskets, or both like i did. Quote
pDuB257 Posted October 29, 2009 Author Report Posted October 29, 2009 On the bottom of what? The radiator? Do any of you guys have pics of what the plug looks like and exactly where it is? I can't find it at all lol. Btw, the oil is fine, it turns black/brown as it normally should after every couple thousand miles. I just need a pic of what the radiator plug looks like that way I can go from there... Quote
cubsfan24 Posted October 29, 2009 Report Posted October 29, 2009 The plug is on the bottom of the radiator and looks like this: http://www.amazon.com/Help-61133-Drain-Cock/dp/B000C5I60O/ref=pd_ts_auto_5?ie=UTF8&s=automotive On my Lumina it is on the drivers side. I broke the tab off of mine so I have to disconnect the lower hose now. Quote
pDuB257 Posted October 29, 2009 Author Report Posted October 29, 2009 Well I noticed there was a plastic cover underneath my car under the radiator. It is probably the radiator guard cover, but do I have to remove that or anything else that may be in the way in order to see that plug? Also, how do you undo the plug to make the coolant come out? Does it twist by hand or do you have to use a tool? Quote
Andrew Posted October 31, 2009 Report Posted October 31, 2009 its easier and quicker if you just pull the lower radiator hose off. May be a bit messy though. Quote
Night Fury Posted October 31, 2009 Report Posted October 31, 2009 its easier and quicker if you just pull the lower radiator hose off. May be a bit messy though. Qft Quote
