manifoldsrme Posted October 28, 2009 Report Posted October 28, 2009 OK, so I have had my 90 TGP about 2 months now and I am just starting to make it road worthy. I had to replace the PMIII and that went well and I have brakes now and the red brake light on the dash went out. Now however, I have no brake lights and when I turn the turn signal on to turn right the light signal just stays on in the dash. Can these 2 issues be related, did I miss something on the PMIII install that could be affecting this? Also, a few wisps of white smoke have come out of my column on ocassion when starting the car. Quote
tunerlover3 Posted October 28, 2009 Report Posted October 28, 2009 http://www.w-body.com/forum/index.php?topic=82283.0 The brakes could be the stop light switch or a fuse(s) Quote
mra32 Posted October 28, 2009 Report Posted October 28, 2009 My turn signal switch is on its way out (or needs a cleaning) and when i turn on my turn signal sometimes, the turn signal and corresponding dash light will remain on solid Quote
manifoldsrme Posted October 28, 2009 Author Report Posted October 28, 2009 If I replace the turn signal switch, could this also fix my no brake lights problem or are they seperate issues? Quote
mra32 Posted October 28, 2009 Report Posted October 28, 2009 I dunno, use the search tool to look up turn signal switch (TSS) threads Quote
tunerlover3 Posted October 28, 2009 Report Posted October 28, 2009 manifoldsrme said: If I replace the turn signal switch, could this also fix my no brake lights problem or are they seperate issues? Pretty sure separate. Quote
mra32 Posted October 28, 2009 Report Posted October 28, 2009 The wisps of smoke would also indicate a turn signal switch. Does your 3rd brake light still come on when you hit the brakes? That doesnt go through the turn signal switch, but i think the brake lights in the tail lights do. Quote
Crazy K Posted October 28, 2009 Report Posted October 28, 2009 tunerlover3 said: manifoldsrme said: If I replace the turn signal switch, could this also fix my no brake lights problem or are they seperate issues? Pretty sure separate. mra32 said: The wisps of smoke would also indicate a turn signal switch. Does your 3rd brake light still come on when you hit the brakes? That doesnt go through the turn signal switch, but i think the brake lights in the tail lights do. they are definitely separate issues ONLY on 1st GEN GPs (what you have) The 1st gen GP uses separate bulbs for turning and braking, thus the TSS does not route power for the brake lights to the rear. All other Ws have a common turn and brake light, where the brake power goes through the TSS, which is what you might have read about while researching. but yes. you have to either service or replace your TSS, and figure out what the seperate brake problem is... and I bet your brake light switch was misaligned when the PMIII was replaced. Quote
94 olds vert Posted October 31, 2009 Report Posted October 31, 2009 mra32 said: My turn signal switch is on its way out (or needs a cleaning) and when i turn on my turn signal sometimes, the turn signal and corresponding dash light will remain on solid Mine just did this today, when I was testing the lights. When I get done driving the car the brake lights remain on until I pump the brake to shut them off. Quote
manifoldsrme Posted November 1, 2009 Author Report Posted November 1, 2009 It took 5 or 6 tries on adjusting the brake switch above the pedal but persistence paid off and the brake lights work now. I checked all the bulbs in the car and about half were / are burned out. I am hoping this is the turn signal problem. I have seen where if you get enough bulbs out in the system other parts wont work. Of course the Autozone by my house was out of both the bulbs I didnt already have so I will go hunting for them again today. I took the car for its first real drive now that I had brakes and brake lights. It runs good most of the time, but occasionally "stutters" a bit. I am thinking tune up and injectors and go from there. I think it is ready for an emissions test and registration. I have to decide if I do it now and then it sits all winter, or I just wait until spring to register it. Meanwhile my daily driver Jeep Cherokee has sprung a leak in the gas tank so no more time for the TGP.........for a while..... Quote
manifoldsrme Posted November 1, 2009 Author Report Posted November 1, 2009 New bulbs fixed everything. All known issues are fixed. Another TGP hits the road! Quote
Crazy K Posted November 1, 2009 Report Posted November 1, 2009 WOOT! I did take for granted that bulbs could be burned out.... as I check mine constantly. TIP: when a rear TS light goes out, they will not flash. when a front primary TS light (not the corner marker one) goes out the dash indicator stays on when they are off. 94 olds vert said: mra32 said: My turn signal switch is on its way out (or needs a cleaning) and when i turn on my turn signal sometimes, the turn signal and corresponding dash light will remain on solid Mine just did this today, when I was testing the lights. When I get done driving the car the brake lights remain on until I pump the brake to shut them off. your brake light switch is very easy to adjust (92+ style) get down there, remove the panel cover and find it, and push it in a notch. If your brake pedal is not returning to the "at rest position" you may need a new booster... Quote
94 olds vert Posted November 1, 2009 Report Posted November 1, 2009 I removed the cover, Grabbed a flash light and I couldn't find anything worth pushing in a notch? I did manage to kill a spider. Quote
94 olds vert Posted November 3, 2009 Report Posted November 3, 2009 I let the car run for a good 15 minutes, never had it out of park.Shut the car off and the brake lights came on. I pumped the brake 3 times and they shut off. Quote
Crazy K Posted November 3, 2009 Report Posted November 3, 2009 it is usually a white plastic switch right which contacts the brake pedal's arm... it adjusts by pushing it in... Quote
94 olds vert Posted November 7, 2009 Report Posted November 7, 2009 Crazy K said: it is usually a white plastic switch right which contacts the brake pedal's arm... it adjusts by pushing it in... thank you, I adjusted it and all seems well. Quote
