cutsup1996 Posted September 15, 2003 Report Share Posted September 15, 2003 my cutlass has the dual fans in the engine bay and I want to know how to hook up a switch to the ac fan, which only comes on when the ac is on, so I can turn it on when I want to. My car has never overheated but a lot of the city driving I do it gets quite warm waiting at lights. I would like to be able to cut that fan on when I want and cool it a little. Anyone done this yet, is it easy? Quote Link to comment Share on other sites More sharing options...
hazmatic Posted September 15, 2003 Report Share Posted September 15, 2003 i just got done reading about it on the w-body site but im gonna wire it to a seperate toggle switch not my ac but my question is befo i go out n pull the relay how to i pull the realy n do i have to disconnect the battery or not Quote Link to comment Share on other sites More sharing options...
cutsup1996 Posted September 15, 2003 Author Report Share Posted September 15, 2003 i wanna do it the same way, separate toggle switch, just dunno what to do, where to splice, disconnect battery, don't wanna mess up ac Quote Link to comment Share on other sites More sharing options...
hazmatic Posted September 15, 2003 Report Share Posted September 15, 2003 this is what im doing i just need to know how to pull the realy n if i have to disconnect the battery http://www.w-body.com/upgrades/manualfancontrol.html Quote Link to comment Share on other sites More sharing options...
Bolt_Crank Posted September 15, 2003 Report Share Posted September 15, 2003 you just kinda rock it out.... and if you disconnect the battery, you won't be able to know which one is putting out the 12 volts I didn't disconnect mine, anyway, just make sure you don't touch the wrong things together, the instructions are almost 100% complete... your primary fan, if you have a switch for it, will be able to be turned on with or with the key on... the secondary will need the key... Quote Link to comment Share on other sites More sharing options...
hazmatic Posted September 15, 2003 Report Share Posted September 15, 2003 im gonna wire my secondary to always be on n let the ecm decide when the primary should kick in Quote Link to comment Share on other sites More sharing options...
hazmatic Posted September 15, 2003 Report Share Posted September 15, 2003 86 nore 85 r the wire with the 12v in my car 30 is what do i do now? Quote Link to comment Share on other sites More sharing options...
Bolt_Crank Posted September 15, 2003 Report Share Posted September 15, 2003 make sure your leads on your tester are making good connections in the sockets.... it took me awhile to find a good enough ground for it to work nicely... Quote Link to comment Share on other sites More sharing options...
hazmatic Posted September 15, 2003 Report Share Posted September 15, 2003 i found a good ground right away on the bolts in the back of the engine bay in the corners i see what i did wrong i forget to turn on the ignition n im guessin 30 is alwasy alive but now since i turned the key it is still live same with 85 Quote Link to comment Share on other sites More sharing options...
Bolt_Crank Posted September 15, 2003 Report Share Posted September 15, 2003 d'oh... forgot about that... heh the rest is easy Quote Link to comment Share on other sites More sharing options...
hazmatic Posted September 15, 2003 Report Share Posted September 15, 2003 ya it is i just got done its up n workin 8) Quote Link to comment Share on other sites More sharing options...
Bolt_Crank Posted September 15, 2003 Report Share Posted September 15, 2003 nice I remember when I did mine up.... lol, sitting in the garage, I could feel the air getting sucked through the rad, 'twas cool Quote Link to comment Share on other sites More sharing options...
hazmatic Posted September 15, 2003 Report Share Posted September 15, 2003 should i do my primary fan 2 n all this does is keep my engine cooler so my engine runs better rite???? im guessin i wont see no performance tho either but the main reason i wanted to do this is cuase my low coolant light has been comin on alot when i drive although my coolant is full so i guess my fans whernt runnin probally n today(i took the day off to work on my car) i did the idel relarn n i noticed my main fan turnin on so i dunno Quote Link to comment Share on other sites More sharing options...
Bolt_Crank Posted September 15, 2003 Report Share Posted September 15, 2003 maybe you need to bleed your cooling system? Quote Link to comment Share on other sites More sharing options...
