Grndzer Posted September 15, 2003 Report Posted September 15, 2003 I am wondering sense the 3.4 was offered in my car the swap should be fairly easy, has anyone done this? Quote
patgizz Posted September 15, 2003 Report Posted September 15, 2003 yes, but i strongly suggest getting a donor car for all the stuff that is different. stick to a 91-93 engine - you will need engine, trans, wiring harness, motor/trans mounts, both heater hose/pipe assemblies, radiator(may or may not, the 3.4 radiator from my donor was the same thickness as my 94's radiator but thicker than my 91's). then theres the alternator cooling ductwork, both throttle and cruise control cables, possibility of the a/c lines depending which compressor you get or have now. expect it to take longer than you expect. i had mine running with 3.1 to running with 3.4 in 2 days, but then it took almost a month to get all the little things sorted out and have it all functioning as stock. Quote
Grndzer Posted September 15, 2003 Author Report Posted September 15, 2003 Ok, so its seems that doing a 3.1 build up would be the easy way out, if i have to hack out the wiring harness and all that I don't think I am will to put that much work in. Quote
Aaron Posted September 15, 2003 Report Posted September 15, 2003 ok find a cheap Z34, easy to find cheap to, expect around 3k$ for a nicely running/lookign auto. it will be so much easier. trust me. ive pulled the 3.4, and thank god i can see how it is supposed to go back together. Quote
