willsboattail Posted October 25, 2009 Report Posted October 25, 2009 Power antenna won't go all the way down... 1 of the power window switches on driver's panel partially dead. Where can I get replacements for them? Quote
94 olds vert Posted October 25, 2009 Report Posted October 25, 2009 Hit up your local junkyard. Try to clean your power antenna, I think there are instructions in the manual. It said to use a cloth and a cleaner product, Not sure what the manual recommends, but I use Windex. Quote
willsboattail Posted October 25, 2009 Author Report Posted October 25, 2009 Thanks!! Junkyard already on my "TO DO" list for several parts, but have to wait for some dry and warmer weather here in North Dakota. Maybe next spring. Car in winter storage anyway! Kevin Quote
tdvs Posted October 25, 2009 Report Posted October 25, 2009 It said to use a cloth and a cleaner product, Not sure what the manual recommends, but I use Windex. You may also want to use some kind of light lubricant after cleaning. Quote
94 olds vert Posted October 25, 2009 Report Posted October 25, 2009 It said to use a cloth and a cleaner product, Not sure what the manual recommends, but I use Windex. You may also want to use some kind of light lubricant after cleaning. NO! Do not do that. Quote
94 olds vert Posted October 25, 2009 Report Posted October 25, 2009 Here is why Worst pic ever, sorry Quote
94 olds vert Posted October 25, 2009 Report Posted October 25, 2009 Notice: Don't lubricate the power antenna Lubrication could damage it. Quote
tdvs Posted October 25, 2009 Report Posted October 25, 2009 Notice: Don't lubricate the power antenna Lubrication could damage it. OOPS Sorry about that. Glad you caught that Quote
ManicMechanic Posted October 25, 2009 Report Posted October 25, 2009 It's never bad to lube your shaft though as otherwise it could get stuck. Neither of you will enjoy that. Quote
willsboattail Posted October 26, 2009 Author Report Posted October 26, 2009 It's never bad to lube your shaft though as otherwise it could get stuck. Neither of you will enjoy that. :lol:EWWWWWWWW :lol:That joke stinks worse than a bad catalytic converter using ethanol blended regular gas!! Kevin Quote
Crazy K Posted October 26, 2009 Report Posted October 26, 2009 a sedan switch is the same as the convertible switch for the drivers door, except the marking are different. in case you can;t find a vert one. also... are you sure it's the switch? Quote
willsboattail Posted October 26, 2009 Author Report Posted October 26, 2009 a sedan switch is the same as the convertible switch for the drivers door, except the marking are different. in case you can;t find a vert one. also... are you sure it's the switch? :question:Not Certain!?! All switches work except passenger door window goes down, but not back up. Have to reach over and use the switch on that door to roll window back up. Kevin Quote
Crazy K Posted October 26, 2009 Report Posted October 26, 2009 a sedan switch is the same as the convertible switch for the drivers door, except the marking are different. in case you can;t find a vert one. also... are you sure it's the switch? :question:Not Certain!?! All switches work except passenger door window goes down, but not back up. Have to reach over and use the switch on that door to roll window back up. Kevin that would be a bad driver's switch. Quote
swift13 Posted October 28, 2009 Report Posted October 28, 2009 i thought you had to use one from a vert cuz of the auto-down? Quote
ManicMechanic Posted October 28, 2009 Report Posted October 28, 2009 No. The auto down is a separate module in the dash. Quote
