tdvs Posted October 18, 2009 Report Posted October 18, 2009 Hope it's ok to put this here, since audio doesn't seem to get as much traffic. Finally came across a Delco 12 disc CD player with the cartridge still in it at the j/y yesterday. Problem is, someone else had tryed to get it out and pulled the side of the cartridge facing out off. Since the side was laying in the trunk, I tryed to get the rest out, figuring I could just glue it back together. I destroyed the rest of the cartridge trying Is there any way to get the cartridge out of the CD player intact when there is no power? Quote
1990lumina Posted October 19, 2009 Report Posted October 19, 2009 I doubt it that whole mechanism is electronic. Now saying that...anything is possible. If you don't care about the actual changer/sounds like it's fucked anyways...I'd just cut the thing apart with whatever tools deemed required. Quote
tdvs Posted October 19, 2009 Author Report Posted October 19, 2009 That's kinda what I figured. Altho, in a post I just read today about moving a power seat in the j/y, using a power tool battery was suggested. I assume, if that could be done with the CD changer, it should eject the cartridge. I also wonder if all those CD changers I come across are really no good????? Quote
rockfangd Posted October 19, 2009 Report Posted October 19, 2009 believe it or not the changers are pretty indestructable. And there is no way to get the cartridge out without powering the unit.For all you know there could be a cd still inside the actual player Quote
jeremy Posted October 19, 2009 Report Posted October 19, 2009 why not just hook it up to a power source Quote
GP1138 Posted October 20, 2009 Report Posted October 20, 2009 I have one of these changers in my Aurora. I need a cartridge for it. Quote
tdvs Posted October 20, 2009 Author Report Posted October 20, 2009 believe it or not the changers are pretty indestructable. So are you saying, at least some might still be good? Quote
tdvs Posted October 20, 2009 Author Report Posted October 20, 2009 why not just hook it up to a power source That idea struck me a couple of posts back. I would use a power tool battery. Do you know which wires give it power? Quote
Addicted2bass Posted October 23, 2009 Report Posted October 23, 2009 I know with aftermarket units like Pioneers you can take the unit apart and there is and manually eject the cartridge. Not sure if that true on a Delco unit though. Quote
ManicMechanic Posted October 23, 2009 Report Posted October 23, 2009 I know with aftermarket units like Pioneers you can take the unit apart and there is and manually eject the cartridge. Not sure if that true on a Delco unit though. I had a Delco 6 disc and a Delco 12 dics...Both WERE rebadged Pioneers. Quote
Addicted2bass Posted October 26, 2009 Report Posted October 26, 2009 Should be easy then. I just did it recently on the 6 disk pioneer in my brothers car. Just take the unit apart and manually pop the cartridge out. Quote
rockfangd Posted October 27, 2009 Report Posted October 27, 2009 I know with aftermarket units like Pioneers you can take the unit apart and there is and manually eject the cartridge. Not sure if that true on a Delco unit though. I had a Delco 6 disc and a Delco 12 dics...Both WERE rebadged Pioneers. interesting. Good to know. I believe mercades and jaguar also are the same Quote
