what is neede to swap ones car over? this 96 lumina ls i have has rear disc and i figure i would remove the rear disc if someone was intrested.. so far i have removed the rear caliper with the mountes still attached and the braked line still attached and the rotors.. are the knuckles needed too? i can remove them if there are any intrest..
I was literally just asking about this and looking this up yesterday, apparently this is what is needed (from two separate lists):
-knuckles
-bearings
-calipers
-hoses
-e-brake lines
-and maybe rotors
* Hubs
* Spindles
* Caliper & Bracket & Bolts
* Rotors
* 1996-99 Monte Carlo rear Disc Brake Hoses
* All Bolts (hub, caliper bracket, trailing arm, lateral link)
That's all apparently from what I could find. I'm fairly interested though it's way earlier than I was expecting to get the parts. It all depends on how much you want for them and how much shipping would be to Canada. I also don't really need the rotors as I would prefer getting new ones.
The calipers still work fine?
yes calipers worked good.. if i was doing the swap i would take them apart and lube the sliders and paint them but its personal preference
Good idea on lubing the parts. I had already planned to paint them as well, given that my fronts are painted it would look weird.
