alexo1us Posted October 9, 2009 Report Posted October 9, 2009 I hear some stories and mine look fine, the issues with them rusting out is it common to all w bodies or just certain units? Thanx Quote
Crazy K Posted October 9, 2009 Report Posted October 9, 2009 year make and model? there are a BUTTLOAD of differences between all the cars... Quote
IRONDOG442 Posted October 9, 2009 Report Posted October 9, 2009 Yeah like the second gen Olds dominates all others! Quote
alexo1us Posted October 9, 2009 Author Report Posted October 9, 2009 Mine is 99 lumi I can fix alot of stuff but i have no patents for body work. since i been doing alot of reading I have been thinking about looking for an 92-96 gtp or somtin. but if they tend to go like that I'm not sure now..... Quote
Crazy K Posted October 9, 2009 Report Posted October 9, 2009 oh, and where are you from? if you are in california, it's not an issue, you know. open the trunk and pull the side rugs back, and look at the area above the trunk. Also look at the body where the trailing arms mount and anywhere on the undercarriage and rockers and stuff. a good move is to do some rust proofing, oil coating, or marine grease on trouble areas. I coat brake and fuel lines front to back on my cars with marine grease. If they are already rusty looking... I consider a "stationary" brake test important, which mean with the car running and in park... slam the brakes hard as you can a few times. it it fails it is better that it fails now and not in an emergency. Quote
5speedz34 Posted October 25, 2009 Report Posted October 25, 2009 Marine grease? I would almost think that too much grease would hold moisture in? Quote
1990lumina Posted October 25, 2009 Report Posted October 25, 2009 Oil/grease repels water so as long as he has the line completely encased with grease it should be alright. Quote
19Cutlass94 Posted October 25, 2009 Report Posted October 25, 2009 undercoating works the best from what Ive seen. Quote
Crazy K Posted October 26, 2009 Report Posted October 26, 2009 undercoating seems to trap moisture. grease to prevent water from getting on the lines and other parts is better, if that grease displaces water. Quote
