supersniperkilla Posted October 3, 2009 Report Posted October 3, 2009 I am so confused. in my cutty the drivers window doesnt go down , but the switch is able to make the passenger window go down...im guessing its the driver window motor (regulator?) or something...if someone could help me figure this out that would be great! Quote
RobertISaar Posted October 3, 2009 Report Posted October 3, 2009 same problem with the 90GP... really don't care ATM its getting cold as shit outside anyways. ......should mention, mine will drop about 1/8" before stopping, then you gotta push it back up and hold the up button at the same time for it to close completely. Quote
94 olds vert Posted October 4, 2009 Report Posted October 4, 2009 Probably the motor if the switch is good. Hold the switch and push down if it goes down the motor is bad, doesn't go down switch is bad. Happened on my dads GTP and we did this test and the switch was bad even though the other ones worked. Quote
jeremy Posted October 4, 2009 Report Posted October 4, 2009 Probably the motor if the switch is good. ....and it's probably the switch if the motor is good...... fwiw...you can manually jump the wires in the harness. If the window goes down, bad switch, if not...bad motor. Quote
supersniperkilla Posted October 4, 2009 Author Report Posted October 4, 2009 k...ill try some of these things and see what happens Quote
Mysteriphys Posted October 5, 2009 Report Posted October 5, 2009 hey I had this problem a month or two back, I popped off the door panel and gave the motor a few good whacks with a claw hammer, works like new now! :-D Quote
