Tie Rod Problems
So I tried to fix my tie rod ends, and after whacking it for several hours with a pickle fork and a sledge, and dropping the car and bolt onto a bottle jack to try and force them appart, all I did was screw up the sleeve in the control arm.
My mechanic had to weld a new piece in.
Is there a "secret" that isn't in the repair manual? I know with my 69 to get the ball joint out you had to hit it with a hammer in a certain spot and everything fell apart (including the rear mouldings, but thats a different forum)
Should I have tourched it, or is this an indicator of something else wrong, or what??
You're supposed to use a screw type puller on it.
My 3-jaw puller wasn't big enough, so I got a Pitman Arm Puller and it worked perfectly.
