don't be fooled by marketing.
the supercharged engine has a higher compression and requires higher octane fuel to prevent predetonation. you put regular in there, and the car has to retard the timing to prevent that, thereby reducing your combustion efficiency and therefore reducing your gas mileage.
A series 1 3800 will get less peformance with premium fuel because its harder to detonate on its low compression engine. I have one and have driven it for almost 150k miles. I've tried all types of fuels.
  • Replies 89
  • Created
  • Last Reply
Top Posters In This Topic
  • Imp558
    23
  • RobertISaar
    13
  • xtremerevolution
    11
  • Night Fury
    11
lol I'm so sick of this argument. People are stubborn about it and just won't listen to facts.
X87
Actually the NA 3800 has a higher compression
BACK ON TOPIC GUYS
Do this and report back.
Go through the standard items.
Spark plugs/wires
Air filter
O2 sensor
Fuel filter
MAF sensor (needs cleaning?)
Dragging rear brakes/park brake cable
Ever done seafoamed the car? That alone boosted a guy 4MPG here in a similar fuel economy thread a week or so ago. Just scroll down some in this section and you'll find it.
Correct, the pistons provide a lower compression on the L67 than on the L36, but doesn't the boost increase compression?
dynamic compression is what I was referring to. just didn't know the name for it.
so this past tank of gas I figured i'd go easy on the car. I'm a field technician for work, so I drive all across the city. I'd estimate 75% highway and 25% city and stop and go traffic. On the highway I kept it at 70-75mph. I pumped gas at a 76 gas station (phillips conoco), and calculated 25.96 mpg.
Not bad for a 208k mile 3800 huh.
I got 15 again this time on 89 octane. Next I'll run some 87. The air filter is newer, and everything else is clean or new except the o2s. I'll have to pick up a set and try that next. Oxygen sensors aren't too cheap but if that fixes it the fuel savings will pay for them and then some. Also need to pick up some seafoam and piss off the neighbors more than usual.
The 02 helped my moms MCSS increase mileage a bit by replacing. And she runs ethanol blended 87 from Express and gets an average of 25 with 50% highway. What I found amazing was having 4 people in the car, full trunk of luggage, and 80mph average on the interstate and got 32mpg. 3800's can be amazing when it comes to fuel economy.
Oh and seafoam does wonders. Did it on my 3100 for the first time at 125k miles, and damn I filled my entire street with smoke... gave me an extra 2mpg overall though. Good luck with your car.
I can't WAIT to seafoam the monte... Should make for quite the show
Yeah, I would just bit the bullet and buy a pair of oxygen sensors. Well worth it considering how much of a difference they can potentially make in regard to fuel economy if they're bad.
Front O2 and Seafoam in a bag in the car now. I just assumed there would be 2 front O2s but there is just the one where that cross over pipe comes into the even side manifold. Glad it only cost $52, instead of $104.
20 MPG here I come! Did the Seafoam, and a more thorough cleaning of the MAF (scary fragile looking), and made a ghetto exhaust scrubber to minimize the smoke and it worked. Once the car cools down I'm doing the front O2, cleaning out the throttle body, and another new air cleaner element.
what exactly am i looking at? i see a bucket and what looks like two pipes entering/leaving the top of said bucket...
A bucket full of water. A real scrubber like in the smoke stack of a factory has jets that mist water into them and catch particles before they can escape. My bucket water got a little dirty but there was very little smoke like others had reported.
I havent done the seafoam in the vacuum lines yet but I plan to here shortly... What lines are used when seafoaming a 3800, how about a 3.4?
I used the one to the brake booster. I put a piece of tubing into it and dunked the other end 1/3 of the way into the can of Seafoam and then used my hand to close around it so it sucked it up like a drinking straw.
Me either! :gr_grin:
i only got a gigantic cloud of smoke the first time i ever did it... lasted for 20 minutes of parked reving/idling, but i'm always disappointed when there isn't as much shit being burnt off... at least i can take comfort in knowing the motor was fairly clean to start with...
I guess in theory my ghetto scrubber may not have done anything. It could have just been that it didn't smoke a bunch? I felt better about it because I live in a very small suburban borough where I'm the only gearhead and they don't approve of my (insert here) already.
I guess in theory my ghetto scrubber may not have done anything. It could have just been that it didn't smoke a bunch? I felt better about it because I live in a very small suburban borough where I'm the only gearhead and they don't approve of my NUDIST ACTIVITIES already.
possible.....
