GMRedline Posted October 1, 2009 Report Posted October 1, 2009 I know its my first post... I searched this forum under the "Cutlass Supreme Convertible" category for the following keywords. L67 L32 swap GTP And did not find anything. I am trying to find out some information on a Cutlass L67/L36 swap into a Cutlass Convertible. I don't have Cutlass right now but planning on buying an 95 sometime in the future. My grandpa worked for Oldsmobile so they are dear to my heart. I currently own a 99 Olds Bravada and a 06 Saturn ION Redline. I am trying to figure out which w-body platform would be a good starting point as donor vehicle. I am looking for a vehicle that is supported by HPTuners since I already own the software. Assuming I would need to use the PCM from a HPTuners supported vehicle and adapt it to the Cutlass. Does anyone know where I can start looking for more info? I did several google searches and all I could find where some youtube videos of a L67 swapped cutlass. Thanks for the help guys. Quote
Night Fury Posted October 1, 2009 Report Posted October 1, 2009 It's been done, if no one responds right away, just keep nagging. I myself don't know much about it other than I'd like one! Quote
jake91 Posted October 1, 2009 Report Posted October 1, 2009 do some searches in the powertrain section you will find a wealth of info there Quote
Crazy K Posted October 1, 2009 Report Posted October 1, 2009 as a general rule of thumb, the convertible section is for vert specific issues, and powertrain in not one of them(it is the same as used in other w-bodies). you should be looking in powertrain, and this thread will be moved there soon. it has been done. i want to say 94vert has done it into a vert, but others have swapped motors into other models, and the info will be the same. Quote
GMRedline Posted October 2, 2009 Author Report Posted October 2, 2009 Thanks guys. I'll go dig around in powertrain for a while. Quote
mfewtrail Posted October 2, 2009 Report Posted October 2, 2009 Check out the forum, articles, etc. over at http://www.motorswap.org while you're at it. There's a lot of L67 swap info over there. Quote
GMRedline Posted October 16, 2009 Author Report Posted October 16, 2009 Check out the forum, articles, etc. over at http://www.motorswap.org while you're at it. There's a lot of L67 swap info over there. I am looking for something specific using an ECU/PCM from an HPTuners supported vehicle in a non HPTuners support vehicle. Do you have a link of any examples? Quote
95 vert Posted October 18, 2009 Report Posted October 18, 2009 I have a 99 Monte/lumina harness if you are interested. Quote
GMRedline Posted October 18, 2009 Author Report Posted October 18, 2009 I have a 99 Monte/lumina harness if you are interested. I might need it. I am still trying to get a hold a Brian T. I need to know if I can tune a 95 Cutlass with HPTs after a L67 swap. Quote
95 vert Posted October 19, 2009 Report Posted October 19, 2009 If you use a (preferably for harness pin match) a 99 GTP/Regal GS PCM it should be tunable. Quote
GMRedline Posted October 19, 2009 Author Report Posted October 19, 2009 If you use a (preferably for harness pin match) a 99 GTP/Regal GS PCM it should be tunable. Repin the ODB port and use a GTP PCM? Right? Will there be any problems registering the vin with HPTuners? Sorry I am still reading up on this swap. Quote
95 vert Posted October 20, 2009 Report Posted October 20, 2009 I don't know about registering the vin. I've never used HPtuners. Maybe someone else will chime in on this. Quote
