My abs light popped on today. Read the manual and it read get the breaks checked.
Any ideas? Not even a week ago my mechanic told me the breaks were fine so just maybe a bad connection is all I am thinking.
Were would be the first place to check for the connection?
Probably a bad ABS sensor.
Or could be a loose wire or connector.
Or a wire that is frayed.
Get it scanned to tell you the code.
So I tried to restart the system with the instructions from my manual. The light was still on.
The light is a constant and not flashing. So, I have breaks just not anti-lock breaks.
my ABS light used to be on constantly for about 4 years...
i disconnected and reconnected EVERYTHING related to it. the wires at the EBCM were broken internally with no visible damage. hack the ends off, soldered/heatshrank in some new wire, lights off.
ABS still doesn't work (thank god), but at least the light is gone...
As, long as the lights off there is no problem. :mrgreen:
light goes off, i punch the brake hard enough for it to come on and most of the time, it lights up for a few minutes and goes back off. never feel it working, nor do i want it to.
its for sissys lol
it interferes with an otherwise excellent driving experience...
mine used to come on all the time (1994 grand prix)
and the way I fixed it was the jump post/shock tower whatever you call it, where you are supposed to jump the car from, gets corroded, so what you have to do is use a drummel tool or digrinder and clean up the corrosion, problem solved. I would try that before throwing money at the car....
Removing the bulb is easier than fixing ABS.
not necessarily. i can at least find the problem in about 30 seconds or less using my ABS ADS for tunerpro...
Half-assed! The W-body.com way!
not for me it isn't...
But not all of us have that capability.
all OBD1 W's can have the capability with less than $60 provided they have a laptop...
All right the problem has been solved. The aux battery post is broken where it bolts down there is a crack. So i just tightened the bolt down and the light went off. Looks like this weekend I am going to the junkyard to find a new one.
this is what fixed mine
pontiacmaniac94 solves this problem again give this guy a gold star :lol:
Bah. ABS. Back in the good ol' days, you had to know how to drive a car without layer upon layer of safety systems to save you.
I like having nothing but two pedals and a steering wheel. :biggrin:
