douellette Posted September 29, 2009 Report Posted September 29, 2009 how did you guys hook up yours? and should i keep the factory in-radiator cooler hooked up with this new cooler or just bypass it all together. thanks. Quote
Drummer Posted September 29, 2009 Report Posted September 29, 2009 with my trans. cooler I just bypassed it all together and put the cooler right in front of the radiator, just gotta find a place to run the hoses. Quote
douellette Posted September 29, 2009 Author Report Posted September 29, 2009 okay, cuz i read somewhere that it was better to keep the factory one hooked up too but wasnt sure if it would be a problem if i bypassed it. and it was thinking about mounting it on the passenger side near the factory lines. Quote
Dark Ride Posted September 29, 2009 Report Posted September 29, 2009 I seem to remember reading it was good to have the radiator endtank hooked up that way the transmission wouldn't get too cool in colder weather. Quote
RobertISaar Posted September 29, 2009 Report Posted September 29, 2009 I seem to remember reading it was good to have the radiator endtank hooked up that way the transmission wouldn't get too cool in colder weather. while the tranny will eventually heat up to a normal temp on its own, in the winter, its much quicker with both in use. i'd vote both. Quote
douellette Posted September 29, 2009 Author Report Posted September 29, 2009 i live in maine so its not particularly warm up hear in the winter haha, and maybe 90's and 80's in the summer. Quote
White93z34 Posted October 1, 2009 Report Posted October 1, 2009 both. without question. liquid to liquid coolers are pretty efficient, and you will be feeding a additional trans cooler cooler fluid to cool down, it will keep things cooler overall. Quote
Dark Ride Posted October 1, 2009 Report Posted October 1, 2009 What order would you put them in? Radiator first, or cooler first? Quote
RobertISaar Posted October 1, 2009 Report Posted October 1, 2009 What order would you put them in? Radiator first, or cooler first? putting it through the external cooler first would be pointless, since it would just heat back up to the radiator temp... Quote
douellette Posted October 1, 2009 Author Report Posted October 1, 2009 so bottom line in the radiator (im assuming thats the return line) is the one i want to run new cooler in line with? Quote
White93z34 Posted October 1, 2009 Report Posted October 1, 2009 I believe top line is return on most setups. yeah you want it to flow Trans out->radiator cooler-> external cooler->trans in Quote
douellette Posted October 1, 2009 Author Report Posted October 1, 2009 does anyone whos installed one of these know which line is the return?? Quote
xtremerevolution Posted October 2, 2009 Report Posted October 2, 2009 after letting it sit for a while, turn your engine on and touch both lines. one will get warm quickly. the cooler one is the return line Quote
94GPGTP Posted October 2, 2009 Report Posted October 2, 2009 the top line is the return for sure.. i know i have added a cooler to both of my cars.. also GM did that so the air would be forced out and be all fluid once its flowing.. Quote
douellette Posted October 3, 2009 Author Report Posted October 3, 2009 the top line is the return for sure.. i know i have added a cooler to both of my cars.. also GM did that so the air would be forced out and be all fluid once its flowing.. alright, so im going to be installing the cooler inline with the top line then? Quote
4door Intl Posted October 3, 2009 Report Posted October 3, 2009 Bah, installing hoses to and from the radiator plus to and from the trans cooler sounds too complex. I had pull a wrecker rad from a '91 Regal GS sedan a few weeks ago thanks to that annoying v-angle crack in the end cap leak that develops in the plastic and luckily for me it had a cooler attached (it was a direct to trans cooler only install too). I took the hoses and installed it the same way on my car. Whenever i repair or replace something on my car i drop the hood and say "YEAH YOU'RE WELCOME". That way my car understands it's fortunate to be repaired at all versus DA CRUSHA and knows not to pull any shit. Quote
xtremerevolution Posted October 3, 2009 Report Posted October 3, 2009 Bah, installing hoses to and from the radiator plus to and from the trans cooler sounds too complex. I had pull a wrecker rad from a '91 Regal GS sedan a few weeks ago thanks to that annoying v-angle crack in the end cap leak that develops in the plastic and luckily for me it had a cooler attached (it was a direct to trans cooler only install too). I took the hoses and installed it the same way on my car. Whenever i repair or replace something on my car i drop the hood and say "YEAH YOU'RE WELCOME". That way my car understands it's fortunate to be repaired at all versus DA CRUSHA and knows not to pull any shit. lol. Its not really that hard. Just buy the correct fittings for the hose attachments at your local auto store and you'll be fine. Quote
94GPGTP Posted October 3, 2009 Report Posted October 3, 2009 the top line is the return for sure.. i know i have added a cooler to both of my cars.. also GM did that so the air would be forced out and be all fluid once its flowing.. alright, so im going to be installing the cooler inline with the top line then? yes here is what u should do b/c thats all i did.. the top line on the radiator follow that down to the tranny hoses at the core support.. where the return line is for the tranny take the hose off the line and run a hose to the cooler and the hose should go on the bottom.. just like GM did.. inlet on the bottom and outlet on top.. Then runs another hose from the outlet of the cooler to the return hose on the tranny.. and just use a 3/8 barb connector andd hose clamps to join the 2 hoses together and your done.. about a 2 hour job start to finish.. i ran my hoses tight under the core support dont worry it wont get damaged because the subframe will hit anything brfore the core support does.. i also used the supplied hold down ties and attached it to the condenser only not both the radiator and condenser.. so you will have to push the radiator out of the way to attach it to the condenser only.. no need to drain any fluid if you can get around it like i did.. Good Luck and hope i helped ya out Quote
