RZB1992 Posted September 26, 2009 Report Posted September 26, 2009 I've been trying to fix the 99 Intrigue I picked up still, and I bought it down to my local mechanic, (with anti lock, trac off, and svs lights on) and the code reader said it had a computer failure and also an abs computer failure. I replaced the ECM, and also replaced the abs computer. Now the abs computer makes a humming noise and will stay on till it kills the battery. Even after replacing both, all those lights are still on. Could it be that the original abs computer wasn't even bad, and that the ECM was just throwing off odd codes since it failed?? Has anyone had this happen to them??? Any advice is appreciated. Quote
slick Posted September 26, 2009 Report Posted September 26, 2009 Could be bad grounds, bad computer, or some other odd problem. Quote
