1979lee Posted September 22, 2009 Report Posted September 22, 2009 Hi again all. The brake booster in My 98 lumina 3.1 149K seems to be hissing when iam stopped, mostly on an hill or an incline, you know pressing fairly hard on the peddle. its a continual HISSSSS let up off of the pedle and its gone. it still stops fine like always. is my booster on the way out? it only has one good pwr assist when the enging is off, (i checked that just a few a go) Ideas, Suggestions lee Quote
Andrew Posted September 22, 2009 Report Posted September 22, 2009 sounds like a vacuum leak. check the brake booster vac line. Quote
1979lee Posted September 22, 2009 Author Report Posted September 22, 2009 sounds like a vacuum leak. check the brake booster vac line. I checked and there is no leak in the line, the hiss is coming from under the dash HISSSSSSSS very noticable , if it is the booster how do i remove it? i last changed on something like 15 years aago on a 78 chevy caprice, it was bolted on and hell to remove. lee Quote
oscar_wilde Posted September 22, 2009 Report Posted September 22, 2009 Maybe the booster itself is leaking air. Or some hose cracked near it. Quote
1979lee Posted September 22, 2009 Author Report Posted September 22, 2009 Well Now It's done poped off the vaccume line to the booster..... iam not driveing this car till i replace the pwr brk bstr... i put the hose back on and it still HISSSSSSSSSSSSSing. so my booster is shot, how do i change it??? Quote
White93z34 Posted September 25, 2009 Report Posted September 25, 2009 I'll assume you have ABS.... disconnect all 4 brake lines, electrical connections, and unbolt the master and pull it out. get under the dash and pull the clip out of the top of the brake pedal get a piece of wood that can fit between the posts that hold the master on turn it like you are unscrewing a cap and it ought to turn right off. then climb back under the dash and slip the rod off the brake pedal as you can now do that. pull the old out insert the new, connect the push rod again. then twist to install the new one. other then that install is reverse of removal. also replace the booster vacuum line if it looks questionable Quote
1979lee Posted September 25, 2009 Author Report Posted September 25, 2009 Hi all Well it was the booster i had it profesionally changed. White93Zed34 No this car dose Not have abs thanksfully!!! thanks for the how to info!!! Quote
