PhatMpk Posted September 21, 2009 Report Posted September 21, 2009 Here shown in this video the boost guage works for awhile then cuts off when the coolant light comes on. It is really struggling to make the car go at high speeds. In these 3 videos it shows a little bit better view of how it struggles between 4 and 5k rpms. Quote
Pontiac6KSTEAWD Posted September 21, 2009 Report Posted September 21, 2009 Couple things come to mind.. Have you gotten the upgraded chip? Could just be the basic driveability problems that the TGP has. Have you checked the injectors? The could be out of spec, and causing a flat line short in the bank, or both banks, depending on how many are bad. The boost guage, that could be a couple things, either the wastegate is opening when it shouldnt, or, more than likely, the boost guage isnt working correctly, like mine. Quote
PhatMpk Posted September 21, 2009 Author Report Posted September 21, 2009 I believe it has the stock chip but I am not sure if the previous owner swapped it out. I replaced one bad fuel injector awhile ago with a Gp-Sorensen from autozone, all the other injector were is there any way to test if it is shorting one of the banks? Quote
Pontiac6KSTEAWD Posted September 21, 2009 Report Posted September 21, 2009 Pulling the upper intake plenum, and OHM checking each one... There is a way to tell if the chip has been upgraded or not, but one of the other TGP gurus would have to tell you how that is done. Quote
PhatMpk Posted September 21, 2009 Author Report Posted September 21, 2009 1-12.3 2-14.7 3-12.5 4-12.5 5-12.3 6-17.1 Quote
Garrett Powered Posted September 21, 2009 Report Posted September 21, 2009 I have never seen one run like that. Quote
Addicted To Boost Posted September 21, 2009 Report Posted September 21, 2009 Your #2 and #6 injectors are bad That's also how mine ran with bad injectors, except it wouldn't run at anything over 1/2 throttle. Quote
GOT2B GM Posted September 21, 2009 Report Posted September 21, 2009 definately sounds like fueling. Swap those 2 injectors, and while your at it, verify your fuel pressure is between 40-45 psi, as well as replace your fuel filter. Quote
Garrett Powered Posted September 21, 2009 Report Posted September 21, 2009 I ohmed out all mine but the ones that weren't right at 12 were less than 12. they were between 9 and 11. not saying I wouldnt still swap those out. do you have a different ecm, or eprom you could try, or have you tried that yet? Quote
fishman517 Posted September 22, 2009 Report Posted September 22, 2009 Let me tell you about bad injectors! My car had some real strange issues, it would start and run fine for about 20 seconds and die, I ohmed out the injectors and they were all in spec, so I pretty much thought they were good. WRONG! not until I put together a test rail/pump/gauge and driver and tested each one by spraying them into a bucket and watching the spray pattern could I consider them good. I had two that would just dribble and two that were leaking. Good luck, it is probably the injectors. Quote
Garrett Powered Posted September 22, 2009 Report Posted September 22, 2009 Let me tell you about bad injectors! My car had some real strange issues, it would start and run fine for about 20 seconds and die, I ohmed out the injectors and they were all in spec, so I pretty much thought they were good. WRONG! not until I put together a test rail/pump/gauge and driver and tested each one by spraying them into a bucket and watching the spray pattern could I consider them good. I had two that would just dribble and two that were leaking. Good luck, it is probably the injectors. I wish I had one of those. I need to test a ton of tgp injectors. Quote
PhatMpk Posted September 25, 2009 Author Report Posted September 25, 2009 Thanks fish I read your thread completely the other day. Going to test them maybe sometime next week. It still runs fine at low speeds, but at high speeds im guessin those are just streamin out fuel instead of a nice mist huh Quote
1989 TURBO GRAN PRIX Posted September 26, 2009 Report Posted September 26, 2009 Just looking over the info you guys have on the 3.1 McLaren Turbo's. I have an 89 GP McLaren that I've have for several years... haven't started it in two years now. It sits under cover in my garage with 7,100 miles on it and it still looks and smells brand new! Interesting to see there are some still around! Jim Quote
Pontiac6KSTEAWD Posted September 26, 2009 Report Posted September 26, 2009 Oh yea, still around. Mine sits, much neglected, on the back porch at my house. But, it already looks like ass. Under the hood thou, screaming little meanie she is.. Quote
PhatMpk Posted October 11, 2009 Author Report Posted October 11, 2009 Replaced all the injectors with these 24lbs injectors http://www.americanmuscle.com/vehipefuin24.html No improvement it hesitates when I hit the gas and still doesnt want to go at WOT maybe switching 02 back to ACdelco?? Quote
Pontiac6KSTEAWD Posted October 12, 2009 Report Posted October 12, 2009 AC Delco, or a Delphi unit. Still same problems? CPS (Crank Position Sensor), or ICM (Ignition Control Module). But thats all I can think of. I cant remember if a bad MAP would cause this problem.. Quote
PhatMpk Posted October 21, 2009 Author Report Posted October 21, 2009 Put the computer scanner back on today, no error codes, fuel pressure gauge is at 42 lbs while starting and while running has 34 lbs of pressure, still hesitates really bad at intersections, doesnt want to run at high speeds Quote
Garrett Powered Posted October 21, 2009 Report Posted October 21, 2009 those are not the injectors that people here recommend unless you know how to tune. if you want to get back to running good before upgrades then get the yellow tops. Quote
PhatMpk Posted October 25, 2009 Author Report Posted October 25, 2009 do u have a part number please? Quote
Garrett Powered Posted October 25, 2009 Report Posted October 25, 2009 search function. ...Its been posted a million times, you will find it. I have never actually used them but everyone loves them that tried them. Quote
mfewtrail Posted October 26, 2009 Report Posted October 26, 2009 Put the computer scanner back on today, no error codes, fuel pressure gauge is at 42 lbs while starting and while running has 34 lbs of pressure, still hesitates really bad at intersections, doesnt want to run at high speeds Starting pressure looks fine, but the running pressure is low. That is, if your gauge is accurate... Quote
PhatMpk Posted October 28, 2009 Author Report Posted October 28, 2009 gauge is accurate starts 44 lbs, 34 lbs while idling, and rises in conjunction with the throttle to about 42lbs at 3,000 Quote
PhatMpk Posted October 28, 2009 Author Report Posted October 28, 2009 Thinking the cat might be clogged Quote
mfewtrail Posted October 28, 2009 Report Posted October 28, 2009 gauge is accurate starts 44 lbs, 34 lbs while idling, and rises in conjunction with the throttle to about 42lbs at 3,000 Just for what it's worth...The pressure on my pump TGP(stock pump & regulator) is no lower than 40-41psi when idling. Key on/engine off, it's about 5-6psi higher than that. Quote
PhatMpk Posted November 5, 2009 Author Report Posted November 5, 2009 so would new injectors raise my fuel pressure? Maybe my fuel pump pulsator is leaking? Quote
