Radnsmash Posted September 19, 2009 Report Posted September 19, 2009 Haven't been on in quite some time, but recently(like a week ago) I hit 120K, and with this many miles, and a car with absolutely no maintenance records(that I could find), what should I consider to replace to keep the wheels turning? I've already replaced a few things, such as: Serpentine Belt Plugs+Wires Battery Tires MAF Sensor(fucker died a few months ago) Air Filter I was thinking next should be a fuel filter(probably gonna go with a Purolator for 9$ from Advanced Auto) But what do you guys think? Quote
White93z34 Posted September 19, 2009 Report Posted September 19, 2009 fuel filters are good to be replaced every year or 2. I'd shake down your front suspension components or have it checked out, balljoints, tie rods and ends, all like to go on our cars, and even more so living in snow states. Quote
Radnsmash Posted September 19, 2009 Author Report Posted September 19, 2009 Which leads me to my next question. Whenever I turn to the left, I hear a very apparent humming noise from the left wheel. Its not the wheel rubbing against the splash guards in the wheel well, I've read this might be a wheel bearing, and a few weeks ago I jacked up the car and shook it vertically and horizontally as hard as humanly possible, and not a budge. The car doesn't pull in any direction...what do you think? Quote
Venom Posted September 19, 2009 Report Posted September 19, 2009 Do you only get the humming while turning, or does it just get louder when you turn? If so, then its definately a wheel bearing. Quote
Andrew Posted September 19, 2009 Report Posted September 19, 2009 fuel filter, pcv valve, t-stat. consider flushing the coolant & brake fluid. trans fluid and filter. Quote
BXX Posted September 19, 2009 Report Posted September 19, 2009 Sounds like a tire with some uneven wear. Bearing should make some sort of noise while driving straight and its pitch will change when turning. Quote
Radnsmash Posted September 20, 2009 Author Report Posted September 20, 2009 Yeah it does get louder the more I turn left, and does give off some noise whilst going straight. As for the coolant flush that was another thing on my list and I'll definetly do the fuel filter. As for the tires, theyre not even 2 months old(4 Hankook Radial117 225/60R/16) Quote
AL Posted September 20, 2009 Report Posted September 20, 2009 Sounds like the passenger side wheel bearing Quote
Radnsmash Posted September 20, 2009 Author Report Posted September 20, 2009 Sounds like the passenger side wheel bearing How could it be the passenger side when the noise is coming from the driver side wheel? Quote
Andrew Posted September 20, 2009 Report Posted September 20, 2009 when you turn left, the weight shifts right, so its likely the right wheel bearing. Quote
Radnsmash Posted September 20, 2009 Author Report Posted September 20, 2009 Alright ill check it out Quote
94 olds vert Posted September 20, 2009 Report Posted September 20, 2009 Something people forget to change is the brake fluid. Or if its low just put some fresh stuff in. Quote
cutty Posted September 20, 2009 Report Posted September 20, 2009 Or if its low just put some fresh stuff in. I would never recommend topping the brake fluid off, unless your changing a caliper and bleeding it. The fluid is low for a reason, meaning your brakes are getting low which makes the calipers use more fluid to push the piston out further to make the pads contact the rotors. Quote
89SupremeCutty Posted September 20, 2009 Report Posted September 20, 2009 Do you only get the humming while turning, or does it just get louder when you turn? If so, then its definately a wheel bearing. i have that problem, only it's not the wheel bearing but a bad tire. Quote
Radnsmash Posted September 21, 2009 Author Report Posted September 21, 2009 What do you guys think about the drilled 180 t-stat from ZZP? Good for a N/A 3800 II? Quote
jeremy Posted September 21, 2009 Report Posted September 21, 2009 What do you guys think about the drilled 180 t-stat from ZZP? Good for a N/A 3800 II? what special about one from ZZP vs. one for a parts store??? Quote
Radnsmash Posted September 21, 2009 Author Report Posted September 21, 2009 What do you guys think about the drilled 180 t-stat from ZZP? Good for a N/A 3800 II? what special about one from ZZP vs. one for a parts store??? That's what I'm asking Quote
jeremy Posted September 21, 2009 Report Posted September 21, 2009 I'd just get one from a parts store.... Quote
Andrew Posted September 22, 2009 Report Posted September 22, 2009 i ran a drilled stat in my L36 just fine. Quote
Imp558 Posted September 22, 2009 Report Posted September 22, 2009 Coolant elbows are a few bucks at advance auto for the set from the "HELP" section. It's an easy job to replace the troublesome top one. Haven't done the lower one but mine's not brittle yet. Quote
