1 - get a custom Birchmount rear leaf to replace your stocker.
2 - convert to rear coilovers.
both of which are covered on this forum. search around.
i dont know if it would work or not or if its even a good idea. but could you put a shim of some sort where the leaf conects to give it a bit of lift
ANSWER: Poly leaf end blocks from NAPA
x32548123569023562
but i got my last 3 sets from rockauto for 1/2 napa's price.
x32548123569023562
Ken you have pictures of these installed? I have to install new tip pads on a monoleaf I got lying around for my new lumina that is missing both sides. Noisy as hell!
my cutlass rose nearly 2 to 3 inches when i installed my new monoleaf isolator pads. first set i installed incorrectly but ever since i have had no problems
This might be a good time to mention that i'm making my own leaf end pads out of commercial floor tile and epoxy. Surprisingly hard yet flexible. I can have the ride height I want based on how many strips I use.
Ghetto yes, but for $0.59 a tile?
I can beat that ghetto fix. When my Cutlass tossed the left square urinal puck-looking end block i just took a piece of wood of the same thickness, cut it into a square, and...here's where my ghetto award comes into play: i stapled strips of cut bicycle innertube to both the top and bottom sides so it wouldn't wiggle out and fly away. It's lasted with nary a budge for months.
how long is that gonna last? And you can get the puck kit for like $11 on the rock.
or NAPA sells brand new glue on rubber ends.
I'll probably pull my leaf again next year, and change the pucks out for the rubber ends. the rear of my car sits just a bit too high now for my likings.
Plus shipping.
Tried those, and they only lasted me year with the FAF leaf.
Plus shipping.
MEVOTECH Part # AXK6544 {Private Label}
FOR REAR TRANSVERSE SPRING; Rear
$15.21 shipped :dunno:
Plus shipping.
Not counting what my experience with these things has been before, how long are they **supposed** to last?
