how to install sensors in cai
okay as you know im doing a cai and i wanted to know how to install the iat and vacuum sensor so i just drill a hole in the pipe and put in a rubber grommet and plug the sensor in of is there more?
IIRC, there is a metal clip inside of the stock tubing that holds the IAT in place. Pull that clip out, and use that in your new metal pipe (use a grommet as well).
Vacuum line, drill a hole, put in a grommet, and pop the line back in.
