digitaloutsider Posted September 14, 2009 Report Posted September 14, 2009 Seriously, the turn signal switch is a 45 minute job at the most assuming you have no idea what you're doing. Get a wheel puller and don't drive the bolts through the SWRC power ring and you'll be fine. Quote
tornado_735 Posted September 14, 2009 Report Posted September 14, 2009 The last time someone here told me "If you have your arms amputated, this should take you 10 minutes" it took me over 3 hours. I'm familiar with a wrench, but I wasn't born with one in my hand. :lol: Lets just hope mine holds out for a bit. Quote
89GP_SE Posted September 14, 2009 Report Posted September 14, 2009 How do I pull the wheel off? I've never had to pull one before. you are gonna need a steering wheel puller, the square one not the hand print one... take off the middle bolt on the steering wheel, then put the steering wheel puller on. Be sure it is centered on the little dot in the middle of the stem.. turn clockwise on the puller till it comes off. For now try pulling in as if you were to click on the high beams when turning on the signal lights, my lumina signals would work if i turned them on then pulled the turn signal stalk a little. sorry for this mixed up message as I am drinking right now, but yeah you get what I mean i hope. I do beleive there is a write up in the FAQ section for this issue. Quote
Addicted To Boost Posted September 14, 2009 Author Report Posted September 14, 2009 Ah so its just like using a flywheel puller then, thanks I did try holding the stalk, that did work for the last month or so, but it completely smoked itself now I move it up and down manually to make the right signal flash now. Luckily almost all of my driving is on the highway anyway. Quote
Night Fury Posted September 14, 2009 Report Posted September 14, 2009 One in my '91 CS would smoke. That was always fun. As for this one, it just barely works, but no smoke Quote
boulevard Posted September 14, 2009 Report Posted September 14, 2009 The last time someone here told me "If you have your arms amputated, this should take you 10 minutes" it took me over 3 hours. Holy shit.. that was funny! I laughed out loud to this one! Thanks! Quote
