EGR removal
how do i remove the egr valve on my 3.1 i got the tree bolts off but how do i get the exhaust part off so i can clean out my egr valve
if you pulled out the 3 bolts you should be able to pull the EGR off. Unless you are trying to ask about the tube that connects from the exhaust?
yes i am talking about the tube that goes to the exhaust
I just did that myself the other day. There are two nuts and one bolt holding it to the intake, which you've already done. The tube that goes to the exhaust pipe is just held by a 23mm (maybe 7/8") nut. It's not the easiest to reach and a wrench that size will be close to your brake lines, so be careful.
