surging
dirt_igirt
i hit the brakes in my 1991 grand prix 3.1 and if i come to a stop it will somtimes stall just started doing it today
on top of your upper intake, near the brake booster. to test it:
connect pin D to a good 12volt source, and then connect pins A B and C to known-good grounds(one at a time) to see if a certain valve is sticking. if the lead arcs and you don't hear the solenoid move, its bad. you should hear it easily if the engine is off.
