1994 3.4l v6 Engine squeal!
No the engine does not actually squeal.
But From the passenger side where all the belts are sounds like its squealing.
This has only started to happen since I bought a foam product to degrees the engine.
And today it would not stop. Any Ideas?
If you guys want to know anything else ask and i will find out for you
..and if replacing the belt doesn't eliminate the squeal, you likely have a bad tensioner.
No not always.
Could be a pulley making the noise as well.
While you have the belt off, spin all the pulleys and wiggle them.
