Power ant problem
It used to go up and down very slowly and now...nothing
does anyone have any idea how to fix one and do i need a new one?
I no it works and the fuse is good
I think it has a lot of corrosion on it so how do i clean that off?
There is an access panel to the trunk it looks like the door should come off, but i have had no luck in getting it off
anyone no how to take it off without breaking it?
Most likely the motor is burned out. Check also to see if it has power going to it.
its very strait forward you will know how to do it when you see it pull back the carpet in the trunk there is 2 screws that hold the anttena bracket to the car you undo those unscrew the ground and unplug it
There is power going to the motor for the ant.
i guess take it a part and take a closer look it so really see whats going on with it
  • 3 months later...
I fixed this a long time ago. If anyone is interested I used one of a firebird convertible. The mount was a little different, but works like new.
time for a replacement. The shaft usually corrodes and the more it does the slower the antenna works, then it finally runs the motor down till it stops working
