Starting Issues
This has been happening on and off for awhile now but it needs fixed ASAP. It seems like this happens usually when it rains. It will turn over and over but not start but it chugs like it will start but not. Sometimes after a while it will start or if i leave it for a long time and come back it will start. Thats not always true but it does happen. I am thinking something ignition related but not sure.
hot start?
cold start?
have you checked for spark while this happens?
Cold only. Hot starts are fine. I will check next time it happens.
cold start....
hmm.
do a test with a screwdriver in the end of a spark plug wire, use an extra wire if you have one.
also, press the schrader valve on the fuel rail to see if you have any fuel coming out.
I tested the fuel pressure last fall with my brother and it was within normal psi. I can hear the fuel pump prime everytime i turn the key. I will check spark.
Sounds like a good start to me. Spark should be good since the plugs and wires are pretty new.
I'm gonna say crank sensor needs replaced.
Don't snap it! If it is still the original unit in there, they are VERY brittle.
