So here's what I did for my Summer Project ... (Warning 56kbps people)
Dash, Integrated CarPC ... that is all. I'm not done with the bezel though ... It needs some good ol' TLC, sanding and such. I know it looks like crap ... but that's temporary [didn't want people to be able to see behind the wood-grain dash cover]. Let me know what you guys think.
Which is correct, carpc or your speedo?
The CarPC is much more accurate than the Speedo. My tire sizes aren't original specs.
That's what I figured.
Most factory speedometers are fairly inaccurate.
IIRC, don't you have a ton of suspension modifications as well?
Wow! If the car wasn't this old (No offense) I'd say that was factory!
Thanks ... No harm done. I quite aware my baby's old. She reminds me everyday I drive her ... but that's nothing some good ol' Polydent and Metamucil can't take care of, lol. Just making some modifications to deter me from cheating on her and maybe purchasing another vehicle ... I've got my eye on a 1996 SVT Cobra as we speak, so she's a little jealous.
I went to type that and had trouble wording it so that it wouldn't sound too mean. But mine's a '92 also. I always say it's the condition, and not the age that matters.
Yeah,
- KYB GR2's Front and Rear w/ Mounts and Boots
- Bir-traxed [98+ Monte Carlo Front Lowering Springs and Birchmount Rear Leaf Spring]
- Addco Rear Sway Bar [actually come to think of it ... that's not even installed yet, lol]
- Energy Suspension Poly Inserts
- Adam's Rear STB
- 2nd Gen Regal Front STB
- 93' Regal Support Braces
- Cutlass Supreme Wheels wrapped w/ 225/50/16 in the Front and 235/55/16 in the Rear
I believe that's it.
So true. The only real problem I have is the crappy GM paint. Plus the owner I bought it from let it sit in the sun for almost 5 years ... oxidation like a mofo.
Not bad!
I had a carputer setup but sold it as I didnt use it too muchn with a new job I got a while back. My drives to work lasted a whoppin 2 minutes tops :lol:
Not bad!
I remember you had one. Actually you sparked the idea for me to do the same to my vehicle. My system boots up in 30 seconds tops (from hibernation). Not too bad.
Did you swap the UB3 into it? :question:
If so I guess I'm number 2, that swap is such a pain with no wiring diagrams.
and i like what you did with the car mod wise, you have any more pics?
Oh yes, I swapped the UB3 in myself. It wasn't too bad ... I searched the forums and found that "Lee" did it before and posted wiring diagrams. That helped a lot.
Btw, I'll post more pics tomorrow.
Current Car Specs/Modifications:
Engine
- Custom 2.5'' Dual Exhaust - $300
Brakes
- 96' Chevrolet Monte Carlo - Strut/Knuckle Assembly - $100 (For Larger Brake Setup)
- 95' Oldsmobile Cutlass Supreme - Rear Brake Calipers - $50
- 11.25in Front Rotors - $45
- Cross-drilled/Slotted Rotors - 11.25in Front - $70.00
- 11in Rear Rotors - $40
Suspension
- KYB Struts - Fronts - $90
- Intrax Progressive Rate Coil-Springs (1.8in Front Drop) - $80
- AWeb80's Rear W-Body Strut Tower Brace - $50
- GMPP Tubular Trailing Arm Kit (GM Part # 12498649) - $33.66
- 93' Regal GS - Front Support Braces
- KYB Struts - Rear - $89.98
w/ Rear Boots - $28.00
- 2nd Gen Buick Regal Front Strut Tower Brace (GM Part # 12498648) - $21.80
w/ ZZP Strut Tower Brace Brackets - $39.99
- Rear Sway Bar "Nutserts" (GM Part # 10114739) - $11.24
- 95' Oldsmobile Cutlass Supreme - Rear Sway Bar Brackets - $20.00
- Birchmount Rear Leaf Spring (made to match Intrax spring drop) - $242
Interior
- UB3 Digital Cluster Swap - $50
- CarPC
Specs:
- Intel D954GCLF2 1.6 GHZ Dual Core Motherboard w/ Mini-ITX Case - $177.51
- 2GB RAM
- 250GB 5200RPM SATA HDD
- GlobalSat BU-353 USB GPS Device - $36.95
- D-Link DBT-120 Wireless USB Bluetooth Adapter - $11.99
- PureAudio USB-SA High Fidelity Sound Card w/ Superbeam Array Microphone - $44.95
- M4-ATX 250W DC-DC ATX Car PSU - $95.00
- Lilliput 7'' EBY701-NP/C/T VGA Touchscreen - $173.95
- Kenwood KDC-MP642U CD/MP3 Single DIN Receiver w/ USB & Aux - $119.00
- Sony 1000W Mono Single Channel D-class Amplifier - $150
- Bandpass Subwoofer Box w/ 12'' Speakers x 2 [Free]
- Scosche 1500W Amplifier Wiring Kit - $40.00
Exterior
- 97' Oldsmobile Cutlass Supreme - 5-Spoke Wheels - $200
w/ 225/55/16 Front Tires and 235/55/16 Rear Tires
- Pinstripping Removal
- GM Keyless Entry Remote - $7
Parts Obtained, But Not Installed
- 95' Oldsmobile Cutlass Supreme - Parking Brake Foot Pedal - $10.00
- Addco 474 Rear W-Body Sway Bar w/ PolyUrethane Bushings - $170
i have to say that is absolutely bad ass! i've tossed the idea around in my head about doing something like that eventually. looks pretty sweet!
Not bad!
Yeah, my main problem was boot time was about 1min 15seconds (yes, I timed it :lol:) I was using a SFF PC instead of something more integrated. I had to use a damn DC to AC Invertor. I would love to do it again, but this time use an appropriate powersupply and build the PC specifically for a car. Man, i do miss that sweet 7" Lilliput touchscreen :lol: :willynilly:
