1997 cutlass supreme vats bypass.
Ok security light is flashing, had a new key made and still no dice. Im assuming whatever reads the resistors in the ignition lock is bad. So im just gonna bypass it, i read the resistor and i need to make a 4.75ohm resistor no big deal.
But what color is the the wire that i have to tap into under the column??? I read orange but it wasnt for a cutlass, just wanted to make sure before i go hacking stuff up.
Thanks in advance, I tryed to search but couldnt find anything.
yes i have seen that site but it isnt for a cutlass, i was just wantin to check to see if anyone has done this with a cutlass and whether or not its still orange.
its for wbodies and your car is a wbody. if i recall from my car correctly, the wire is indeed orange
to be techincal... the wires are black and white... and they are in an orange sleeve.
:lol: uh huh
yup did it last night works great. i made mine easy disconnect for when its in winter storage too...
I just went out and checked, mine were 2 white wires inside the orange sleeve.. so HA!
oh, in the column half of the harness. :lol:
