AL Posted September 2, 2009 Report Posted September 2, 2009 If you have pictures of installs or anything thing else that can help with connector identification, can you please post them? Any help would be greatly appreciated. Quote
White93z34 Posted September 2, 2009 Report Posted September 2, 2009 can you take pictures of what you presently have? Quote
AL Posted September 2, 2009 Author Report Posted September 2, 2009 it is at school... I put my camara in my car and ill take pics tomorrow Quote
AL Posted September 4, 2009 Author Report Posted September 4, 2009 Where do these plugs go? Placement of the previous three plugs Quote
RobertISaar Posted September 4, 2009 Report Posted September 4, 2009 as far as i can tell, all of them except for the 5-wide one go to your continuum transfunctioner.. the 5-wide goes to the flux capacitor... rookie Quote
94GPGTP Posted September 4, 2009 Report Posted September 4, 2009 Vss I believe is the 2nd one and the 5 one is that the dis? Also a couple other look like dis ones. Also I thought the female 2 pin is the reverse lights Quote
Crazy K Posted September 4, 2009 Report Posted September 4, 2009 help us out. some of the connectors you show are impossible to verify because we cannot see the wire colors, or the position in the harness. cannot tell. too many connectors look like that one. wire colors??? Placement??? looks like either a vss connector, or an a/c compressor connector. are it's wires twisted purple and yellow? are it's wires twisted purple and yellow? this the same as the last pic? this is the crank sensor to ICM wire if so. could this go to a remote relay box for your foglights? coolant level sensor? could that be for the passenger side fan? Placement of the previous three plugs Quote
ss427 Posted September 4, 2009 Report Posted September 4, 2009 2 is the VSS, you can see the O2 sensor behind it. 4 looks like the crank position to DIS. 5 I believe is the AIR pump assy. 7 looks like the coolant level switch. Not sure on the others without wire colors or placement in harness. Steve Quote
AL Posted September 4, 2009 Author Report Posted September 4, 2009 Thanks for the info! I will try to get better pics of the ones I am not sure about... Also, what is the proper routing for the harness, is there a diagram somewhere? Quote
slick Posted September 4, 2009 Report Posted September 4, 2009 As I told you before Alex, the harness, when put into the engine bay properly, will pretty much just fall into place. All of the connectors will only reach it's appropriate plug (or nearby atleast). You need to cross reference the wire colors to the # of pins on the plug, and put it in the correct place. Quote
White93z34 Posted September 4, 2009 Report Posted September 4, 2009 every time I've reinstalled an engine from the bottom I will connect up the harness and put the fuse box/ecm connectors/c100 on top of the plenum and once installed they more or less fall into place. some of the wires require a little bit of fancy routing to get where they need to be but its nothing bad at all. the part that runs across the front of the engine is supposed to be affixed the the radiator support. I wish I was closer. I'd gladly give you a hand. Quote
Addicted To Boost Posted September 4, 2009 Report Posted September 4, 2009 #2 is definitely for the VSS. I remember that one Quote
