Mach Jace Posted September 1, 2009 Report Posted September 1, 2009 So both regulators are out on my two back windows and I've gotta buy some new regulators for 25 bucks each. However, there's also the option to purchase them in a set with the motor for an extra 25 bucks each. Is it worth it to replace the motor and the regulator for 50 bucks? Or should I just replace the regulators by themselves? Quote
AL Posted September 1, 2009 Report Posted September 1, 2009 They are 1 unit I believe so you have to get them together... I always j/y mine because the ebay ones last about a week Quote
xtremerevolution Posted September 1, 2009 Report Posted September 1, 2009 he's getting these off of rockauto. the motors are still good on his current doors. rockauto sells either just the regulators, or the regulators and motors as a set. Quote
GP1138 Posted September 1, 2009 Report Posted September 1, 2009 The rear window regulator assembly on '97+ GP's is pretty much an all-in-one affair. It's cable-driven. I remember looking for the regulator only when I needed one and being disappointed. They're not at all hard to replace, I did it at the July W-body meet in like 20 minutes with Jay breathing down my neck the whole time. Quote
Mach Jace Posted September 1, 2009 Author Report Posted September 1, 2009 20 minutes of hardcore heavy breathing, sounds tantalizing, I'm down. Quote
rockfangd Posted September 1, 2009 Report Posted September 1, 2009 i say because it is the rears i would reuse the old motors, but if it was the front i would say replace them Quote
IRONDOG442 Posted September 1, 2009 Report Posted September 1, 2009 The motors almost never go bad, the cables get out of track or the nylon tabs holding the cable to the actual window regulator fail. or the nylon sashes holding the regulator to the window break off or come unglued. I have torn these apart before and had sucess repairing them. Its very difficult but if you have time do it for fun and the educational experience and challenge. The ones Rock Auto sells are Doorman regulators and are pretty good, the ones on ebay will last a good time if you install them properly. Many times the window track itself gets damaged when they fail and a bent or out of place window track will make any new regulator fail before it should. I have used OEM, Doorman and the cheap ebay regulators on G bodies, N bodies w bodies, and 360 T trucks with equal sucess. A good way of extending the life of these units both new and used is lubricate them with a good silicone based grease. 5 minutes extra on a careful installation will save you alot of headaches down the road. Quote
Crazy K Posted September 1, 2009 Report Posted September 1, 2009 I've been using white lithium grease... Quote
xtremerevolution Posted September 1, 2009 Report Posted September 1, 2009 I figure you can buy a lot of tools for $50. Quote
Mach Jace Posted September 1, 2009 Author Report Posted September 1, 2009 50 dollars could also buy you a nice big canister of anal lube for when you get back to Chicago to reunite with your Big Black Secret Lover Tyrone. Thanks for the help guys, I think I'm just gonna go with the regulators on this one. After all they ARE the back windows anyway and they really aren't that important, I just want to fix them because one of the windows is sagging a bit and there's an airflow that seeps in the car from the crack. Hopefully the tracks are okay, otherwise in a few months from now you'll probably see another post titled "OMGWTF". Quote
sl3196 Posted September 1, 2009 Report Posted September 1, 2009 I'm ordering myself a regulator for the front window right now haha. Is it a total bitch to hook up those cables to the window frame? Didn't look too awful bad when I checked it out. Quote
Mach Jace Posted September 2, 2009 Author Report Posted September 2, 2009 Im guessing it'll be a bit harder then the backs, but its an overall easy job as long as you know how to run the cables. Quote
xtremerevolution Posted September 5, 2009 Report Posted September 5, 2009 Im guessing it'll be a bit harder then the backs, but its an overall easy job as long as you know how to run the cables. Yep, so long as you have the repair manual (haynes, etc.). And actually read it, of course. Quote
