GP1138 Posted September 1, 2009 Report Posted September 1, 2009 but it sounds much too involved says the guy rebuilding a jag v-12 Quote
RobertISaar Posted September 1, 2009 Report Posted September 1, 2009 the main thing that would scare me away Andrei, is that you are OBD 1.5. not so fast... Quote
Crazy K Posted September 1, 2009 Report Posted September 1, 2009 the main thing that would scare me away Andrei, is that you are OBD 1.5. not so fast... RED GTP did it on his 94 GP, and then to a 94 CS..... and you can also convert to a different PCM... Quote
RobertISaar Posted September 1, 2009 Report Posted September 1, 2009 K: those were probably 3.4 cars, right? well andrei has a L27, but luckily, the 1995 L36($5B6) code was cracked and it uses the same PCM, meaning, using a base BIN from a 95 L36, you have a tuneable PCM... unfortunately, the person who made the XDF didn't stick the manual transmission option flag in it..... if/when i find it, then he can do it without swapping PCMs.... Quote
Crazy K Posted September 1, 2009 Report Posted September 1, 2009 K: those were probably 3.4 cars, right? well andrei has a L27, but luckily, the 1995 L36($5B6) code was cracked and it uses the same PCM, meaning, using a base BIN from a 95 L36, you have a tuneable PCM... unfortunately, the person who made the XDF didn't stick the manual transmission option flag in it..... if/when i find it, then he can do it without swapping PCMs.... yes. RED GTP wired it in with the OBD 1.5 PCM, but set it up so the car thought it was in drive except when the clutch was pressed in, utilizing the clutch switch. Quote
LuminaPower92 Posted September 1, 2009 Report Posted September 1, 2009 Eventually My maui Z with hopefully be converted. Quote
jake91 Posted September 1, 2009 Report Posted September 1, 2009 only in my dream will mine be converted LOL Quote
RobertISaar Posted September 1, 2009 Report Posted September 1, 2009 K: those were probably 3.4 cars, right? well andrei has a L27, but luckily, the 1995 L36($5B6) code was cracked and it uses the same PCM, meaning, using a base BIN from a 95 L36, you have a tuneable PCM... unfortunately, the person who made the XDF didn't stick the manual transmission option flag in it..... if/when i find it, then he can do it without swapping PCMs.... yes. RED GTP wired it in with the OBD 1.5 PCM, but set it up so the car thought it was in drive except when the clutch was pressed in, utilizing the clutch switch. thats a ghetto method but it will work. i MAY have found the manual transmission option in the 5B6 code, but the clutch-switch trick is a surefire thing.... well andrei, got any decision on the situation? once a good L36 PROM is found, then you'll have a tuneable car and can run a 5 speed if you want. Quote
xtremerevolution Posted September 1, 2009 Report Posted September 1, 2009 K: those were probably 3.4 cars, right? well andrei has a L27, but luckily, the 1995 L36($5B6) code was cracked and it uses the same PCM, meaning, using a base BIN from a 95 L36, you have a tuneable PCM... unfortunately, the person who made the XDF didn't stick the manual transmission option flag in it..... if/when i find it, then he can do it without swapping PCMs.... yes. RED GTP wired it in with the OBD 1.5 PCM, but set it up so the car thought it was in drive except when the clutch was pressed in, utilizing the clutch switch. thats a ghetto method but it will work. i MAY have found the manual transmission option in the 5B6 code, but the clutch-switch trick is a surefire thing.... well andrei, got any decision on the situation? once a good L36 PROM is found, then you'll have a tuneable car and can run a 5 speed if you want. Once the jaguar is done and running properly, I'll start searching for a 282 (as I hear that 282's are rebuildable, and 284's are not), and everything I need for the conversion, but that might not be for another few months, maybe even half a year, and that's assuming I feel like pulling a transmission during the winter. It would probably be done next year in the spring, or right after I find a 95 L36 PROM, if funds permit. First ever 1st gen regal 5 speed swap? First ever L27 5-speed combo? Sounds very intriguing. How much can I get a 5 speed and all the parts for? Quote
RobertISaar Posted September 1, 2009 Report Posted September 1, 2009 first ever 5 speed regal, period as far as i know... i've seen members here selling stuff for the full conversion for less than 500. i tried getting a 282 conversion from J a LONG time ago and he was willing to let it go for a little over 300. correct on the 282/284 situation. and seeing how L27s like to make their torque in the lower RPM ranges, rebuildable is a plus. Quote
xtremerevolution Posted September 1, 2009 Report Posted September 1, 2009 I wonder what my 1/4 mile times would be with a 5 speed swap. I was at 16.1 before I ported the LIM and put in the roller rockers, and that was in hot and humid weather. Quote
RobertISaar Posted September 1, 2009 Report Posted September 1, 2009 someone here picked up over an entire second from a 5 speed swap alone.... very recent thread too... Quote
rockfangd Posted September 1, 2009 Report Posted September 1, 2009 all i can say on this thread is that if something i going to go it wont matter what trans is in it. now in a very small way it does make a tiny bit of sense, although i know it is not very related, My 2 trucks 1990 Chevy scottsdale 5spd manual revs higher than my 1994 chevrolet silverado automatic but i wouldnt even hesitate rethinking a 5speed swap Quote
RobertISaar Posted September 1, 2009 Report Posted September 1, 2009 it revs higher because you force it to... not at all related to it being "broken in" with an auto. that is the single stupidest thing i've heard today, and probably all week and my wife is trying to convince me london isn't in england Quote
RobertISaar Posted September 1, 2009 Report Posted September 1, 2009 inside of amsterdam..... don't ask why, cause i have NO fucking idea how she came to this conclusion. Quote
tornado_735 Posted September 1, 2009 Author Report Posted September 1, 2009 Well, the story didn't come from me, I just wondered if there was any basis to it. From the sound of things, no. Quote
RobertISaar Posted September 1, 2009 Report Posted September 1, 2009 Well, the story didn't come from me, I just wondered if there was any basis to it. From the sound of things, no. maybe in backwards land, but even then don't count on it... Quote
rockfangd Posted September 1, 2009 Report Posted September 1, 2009 lolThe way i figure it is tha whether it be auto ormanual it still has the same rev limiter Quote
RobertISaar Posted September 1, 2009 Report Posted September 1, 2009 lolThe way i figure it is tha whether it be auto ormanual it still has the same rev limiter true.... unless you're running something from before the 1980s... Quote
IRONDOG442 Posted September 1, 2009 Report Posted September 1, 2009 If you start revving an engine in a higher range than it was normally run at you can break the top rings. The pistons are used to stopping at a certain place, higher revs will push them out a little farther. Happened to my first mustang, had to use a ridge reamer. :facepalm: WTF are you smoking? LMK I want some!! The piston is only capable of rising as far as the connecting rod will allow it to physically travel, theres no way in hell a 6000 rpm rev will stretch a connecting rod and allow more upward travel. Physics is obviously not your forte. There is zero difference in what the rev limiter in the ECM of a manual or auto trans equipped vehicle. The transmission has absolutely ZERO bearing on an engines red line. Quote
hotrodolds Posted September 1, 2009 Report Posted September 1, 2009 But, an automatic 3.4 DOHC car has shift points at 6000rpm to save the trans. A manual 3.4 DOHC car has the rev limiter over 7000rpm. The additional amount of stretch has to be minimal. If you wanted to get the revs up there, a manual is the best way to do it. Quote
xtremerevolution Posted September 1, 2009 Report Posted September 1, 2009 But, an automatic 3.4 DOHC car has shift points at 6000rpm to save the trans. A manual 3.4 DOHC car has the rev limiter over 7000rpm. The additional amount of stretch has to be minimal. If you wanted to get the revs up there, a manual is the best way to do it. The thing is, there is no stretch. Not arguing with you, since I agree the manual can allow you to rev slightly higher, but that doesn't affect the travel of the pistons. Seriously, that notion is flawed on so many levels. If people made an engine with connecting rods THAT flexible, you'd have issues with compression changing as your RPMs rise, and it would be a nightmare to tune and adjust timing for. Connecting rods don't stretch; its that simple. Not that I'd have to worry about it if I 5-speed swapped my regal, since this engine doesn't make much power past 5000 rpm anyway. I can get it to 5400 in 2nd gear but that's as far as it will go, and that last 400 rpm don't do much. Quote
RobertISaar Posted September 1, 2009 Report Posted September 1, 2009 those are shift points, not the rev limiter. of the 4 3.4 DF BINs i have, 3 are automatics and the rev limiter is as follows: Automatics AWMJ: 6050 BCDY: 6050 BHAK: 6050 Manuals: BCFA: 6300 there is only a 250RPM difference. if THAT is enough to kill the motor, it was going to go soon anyways... Quote
